PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
The 3rd gear stumble is gone!
Old 06 Jun 2004, 11:33 am
sakigt sakigt is offline
Send a message via AIM to sakigt
Default The 3rd gear stumble is gone!
*knocks on wood*
Replaced the plug wires with the mopar ones. Went to pull the 4th wire out and it only half of it came off. I cant believe a car with 20K miles could have wires in such bad shape. Test drove it and I could not replicate the problem on high speed partial throttle passes. Awesome. [8)]
When its time to install Stage I Ill probably replace the coil while Im at it...just in case that was the root of this problem.
Old 06 Jun 2004, 12:33 pm
LAF LAF is offline
The root of the problem is HEAT.
I used LiveWires 10mm, Blue, and a MSD coil. I liked the LiveWires because of the composition and the heat shields built onto them, pricer than the Mopars though.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge.
Elbert Hubbard (1856 - 1915)
2003 Electric Blue GT- 7600 Miles on the clock
Stage 1, Mopar BOV, Brand X Air Box Pipe, K&N drop in, White silencer removed, Black lower silencer cut, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axel back exhaust, Rear Spoiler.
Greddy Profec II B, Turbo Chargers Wastegate set to 13#
Bag Stage II :-p
vB code is On
Can't(VERY HARD) get into gear !!! HELP!!! Ctown Tech & Performance Forum 4 25 Feb 2005 01:56 pm
p0733 Gear 3 Incorrect ratio p0733 Gear 3 Incorr RobGT General Turbo Discussions 12 04 Nov 2004 02:02 pm
Blown Gear box after Turbo Charging Kboom General Turbo Discussions 4 27 Oct 2004 05:38 am
Trouble shifting into 3rd gear on 5-speed GT purplept General Turbo Discussions 23 28 May 2004 12:00 pm
and so it begins 026TB4U General Turbo Discussions 3 13 Jan 2004 07:04 pm
  Consolidate Student Loans | Debt Consolidation | Online Loans | Ringtones | Ringtones
