Engine failure
Old 10 Jun 2004, 06:05 pm
Send a message via AIM to GTCruiser2003
Default Engine failure
Well, today i took in the gt for its 30,000 mile service and for a noise it had been making for about 2 weeks. the noise sounded like when you stick somthing in a fan, sort of like a loud clack clack clack, cant really explain in words. I dropped of the car today like at 9:00am at the dealer and told them about the noise. when they turned on the car it started making it so im like ok, at least they can do something about it since they heard it, because if they cant replicate the noise they wont do a thing about it. then later today the service advisor calls me up to tell me that they finished doing all the service, i then asked him if thay had found the cause of the noise. he then tells me that when they tried to start up the car, it wouldnt turn over with the key, so they had to do it manually. when they finally got it on the engine stalled and will not turn on anymore. so now im gonna have to wait like a week for them to get a new engine so they can put it in. they couldnt tell me what caused the engine to die right now until they brake it apart and see what cause the malfunction. will post when i get the results.
Old 10 Jun 2004, 06:12 pm
hmmmmmmm new engine in 1 week and under warranty most likely. Eventhough, it may sound like a long time, but your getting a new engine. You got some extra years off your GT, if they install the engine correctly.
Old 10 Jun 2004, 06:50 pm
If they are putting an engine in it they are not even going to break down the old one. They don't get paid to do that.
Old 10 Jun 2004, 07:31 pm
all i know is they better put on my BOV cause it was a PITA to install. maybe i should get some AM motor mounts installed while the engine is out?? hmmmmmm.... dam more mods.[8D]
what are some good motor mounts and where can i get them??
Mods: Mopar BOV, silencers removed, cowl weather strip removed,Goldline slammers,CarPuter,Greddy Turbo Timer, rearview mirror TV, XBox, PS 2, Alpine Type X components, Pioneer AVIC-N1 Head Unit, fully sound dampend interior, custom fiberglass sub box, Rockford Fosgate Power HX2 15\", Hollywood Audio Amps, red underbody neon, Inferno Red airbag cover, instument cluster, and center console, red door inserts, red headliner, APC Gen2 tailights(POS),removed hood and side emblems, tinted front windows.
Work in progress: Fiberglass headliner, Autometer boost,water temp, and Oil Pressure guages.
JUST THE BEGINNING.......
http://community.webshots.com/user/gtcruiser2003
Old 10 Jun 2004, 11:25 pm
quote:Originally posted by GTCruiser2003
all i know is they better put on my BOV cause it was a PITA to install...
Just count your blessings as some dealers might hassle you about having that performance modification--Mopar BOV--and tell you this caused your engine failure and voided the warranty. [V]
Good luck.
Old 11 Jun 2004, 10:33 pm
Been there done that, First it was S1, then the BOV. In the end they couldn't figure out what burned those 4 exhaust valves So 7/8 weeks later it was fixed for free. They even threw in a nice big scratch, another 2 weeks later IT was fixed for free. Thanking my lucky stars [?]
Old 02 Jul 2004, 03:01 am
Well, today after 3 weeks i finally got my GT back. they gave me a report of what they found wronge with the engine and it reads: "knocking noise from lower engine. Perform compression test cyl #4 low. remove oil pan found metal throught lower engine, thrust bearing worn all the way down. correction: replace short block w/ turbo charger & transfer over all parts" im glad i finally got my car back but i have one question. When i took the car in for its 30000 mile service, it died on the dealer before they did anything, and the still charged me $347.00 for the service even tho they had to drain all the fluids regardless to replace the short block. the bill came out to be $3052.41. i understand paying for the tire rotation and the various filters but should i have to pay full price for the service? when asked why i had to pay they told me that what they did wasn't covered under warranty. i then proceded to point out that they had to do most of the things anyway. i let it go cause i was getting pretty angry and didnt what to argue whith them how they were gonna do 90% of the things anyway. should i call chrysler and argue my case or is it a lost cause already??
Old 02 Jul 2004, 03:25 am
Are you saying you paid for the short block? That it wasn't covered under warranty?
$347 for the 30,000 mile check. WOW! My service supervisor told me it would cost me $100 to change the plugs so I told him I'd do it myself. I don't need an air filter because I have an intake. The rest of the inspecting tie rods and boots, the replacing the pcv air filter and adjusting the generator tension belt should cost me $100 or less of which half of that will be for my oil change with Castrol Syntec. I deal with the same guy all of the time. Last Saturday when we picked up my wife's '01 (catalytic converter failure fixed for free under warranty) we went over the 30k checkup in the owner's manual and arrived at that estimate.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 02 Jul 2004, 03:40 am
i just paid for the 30000 mile service. the total bill for everything came out to $3052.41.
Old 02 Jul 2004, 08:17 am
GTCruiser2003,
Let me get this straight, you paid $3,052.41 for the 30K service????
Holy S%^& dude! You were bamboozled, hornswaggled, flimflammed, and any other word for "taken."
I would LOVE to see the itemization for the bill. Break it down for us.
The worst tune-up/inspection bill I have ever seen was $500. Did they give you liquid gold as your oil? Wait, did they at least kiss you before you went home?
GOOD GRIEF!!!!
You shouldn't be paying a DIME for the engine swap since it was covered under the 3yr/36K bumper-to-bumper warranty, let alone the 7yr/70K powertrain warranty.
Get your money back! Call the Chrysler help line! DO something!
Scott
\"If you choose not to decide, you still have made a choice.\"
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Engine problem BORICUA Tech & Performance Forum 49 03 Apr 2006 05:15 am
Turbo Engine Replacement Bigphil3232 General Turbo Discussions 9 17 Nov 2004 05:43 am
TSB 1802903: Engine Misfire PTskilla General Turbo Discussions 0 18 Aug 2003 12:13 am
