Simple free hack to keep your charging voltage at 14.4V
Like Tree3Likes
  • 3 Post By _PTGT03
Old 11 Nov 2016, 10:45 pm
_PTGT03's Avatar
Talking Simple free hack to keep your charging voltage at 14.4V
From the service manual;
VOLTAGE REGULATOR
The Electronic Voltage Regulator (EVR) is not a separate component. It is actually a voltage regulating circuit located within the Powertrain Control Module (PCM). The EVR is not serviced separately. If replacement is necessary, the PCM must be replaced.
The amount of DC current produced by the generator is controlled by EVR circuitry contained within the PCM. This circuitry is connected in series with the generators second rotor field terminal and its ground.
Voltage is regulated by cycling the ground path on SBEC vehicles or the power side on the NGC vehicles, to control the strength of the rotor magnetic field. The EVR circuitry monitors system line voltage at the PDC and calculated battery temperature or inlet air temperature sensor (refer to Inlet Air Temperature Sensor, if equipped, for more information ). It then determines a target charging voltage. If sensed battery voltage is lower than the target voltage, the PCM feeds the field winding until sensed battery voltage is at the target voltage. A circuit in the PCM cycles the feed side of the generator field at 250 times per second (250 Hz) , but has the capability to feed the field control wire 100% of the time (full field) to achieve the target voltage. If the charging rate cannot be monitored (limp-in), a duty cycle of 20% is used by the PCM in order to have some generator output. Also refer to Charging System Operation for additional information.
Have you checked your alternator charging voltage lately ? How about when your car is warmed up and running, and just after you cranked it to start ?
A properly operating charging system should never really go below 14.4 volts. After starting the car, the charging system should go to 14.7 volts and slowly decline to 14.2 or 14.4.
In fact, my charging system never went higher than 13.7 volts when cold, and as the engine warmed up it would often stay at 13.2 volts, which is far too low.
With winter season upon us, a low charging voltage will recharge batteries slower and could end up by contributing to battery failure.
We can determine on turbo models the battery temperature sensor determines the alternator voltage. The sensor is a simple thermistor. Over time, the material in the thermistor breaks down and becomes out of calibration. The engine computer sends 5 volts to the temperature sensor and determines the voltage drop as a function of its temperature, which is used as an actuating signal to drive the voltage intensity the generator can produce.
I installed a 47K, 1/8 watt resistor in series with the wiring harness leading to the battery temperature sensor. My sensor measures about 10K ohm at room temperature. Adding these values up gave 57K, and before choosing that resistor size I had used a 100K ohm potentiometer to test what and acceptable range would be to keep a high charging voltage without triggering any engine codes. Initially I had used a 39K resistor but it was a little bit too low and I chose to go with a 47K. In my case, the resistor was in my electronics parts bin, and so I consider it free as well !
Hope this can be a free little hack to those who were wondering why there alternator voltages were always low for no good reason.
Old 12 Nov 2016, 07:04 am
Default Re: Simple free hack to keep your charging voltage at 14.4V
I don't suppose you have a picture of this, do you? And where did you purchase the resistor?
Old 12 Nov 2016, 09:38 am
rob302's Avatar
You should monitor your voltage before deciding whether to do this or not. I have a voltage gauge in my Ford and after modifying my charging system, i watch the gauge sit high in the morning on the freeway when all the lights and heat are off and the rpm's are up..
What is your voltage after driving on the expressway for 20 minutes with all accessories off? Any way you can check? You might be surprised.
Old 12 Nov 2016, 06:16 pm
_PTGT03's Avatar
Of course. I have already addressed monitoring my voltage before deciding to do this, or else there would be no point of doing this modification.
14.5 volts. I have a radar detector that displays the system voltage. And as well I have a fluke multi meter which displays the average voltage over time.
Old 12 Nov 2016, 06:21 pm
_PTGT03's Avatar
Shown in here photo is a 39K resistor. I later changed it to a 47K resistor. You can find a resistor in pretty much any electronics supply store. If you wanted to undertake this project you would need to solder some wires and use a resistor colour code sheet.
I later covered all the connections with heat shrink wrap.
Tags
alternator, battery, charging, voltage
Hillbilly hack for battery terminal twodees Sound and Security Forum 8 03 Jan 2016 05:45 am
Charging Voltage = 15+ ?? philbaz Tech & Performance Forum 9 22 Jan 2013 04:20 pm
p1594 " charging system voltage to high" russ00001 Tech & Performance Forum 9 16 May 2012 03:08 am
Charging system battery voltage DJmart Tech & Performance Forum 19 14 Sep 2011 11:26 pm
Electric Taxis Cannot Hack It On City Streets skylight PT Cruiser News and Rumors 3 16 Jul 2007 04:19 pm
