I have a 2005 PT Touring Convertible Turbo (turbolite). This car is new to me, so I'm working out its defects. Coolant is seeping out the top radiator seam, and I don't believe radiator stop leak does anything but plug up heater cores. So, I'm in the market for a new radiator. For those that don't know, the turbo uses a radiator with a removable inlet. From what I can tell, the removable inlet allows one to replace the electric cooling fan, which I did earlier, and which solved my overheating problems. The replacement radiators have a little disclaimer that says 'radiator does not have a removable inlet...installation may require removal of the turbo'. Huh? The turbo is not near the inlet to the radiator. The removable inlet is on the top of the tank on the right-hand side...the upper radiator hose attaches to it. I'm thinking the removable inlet is to allow access or removal of items like the electrical fan. I guess one could install the electrical fan and radiator as an assembly? Has anyone tried this, or should I just get the Chrysler radiator? There's a big difference in price. The turbo radiator with the non-removable inlet is $60. The Chrysler radiator with the removable inlet is around $220 on ebay. So, what have other turbo owners done? Have you been able to use the aftermarket radiator with the non-removable inlet, or did you go with the original Chrysler design?
![]() Quote:
It may be that what they mean is the intake manifold and not the turbo. However, that's not really required either. It may be a typo from a service manual that's been repeated by the radiator manufacturers. If you look at my footer below, you can see the blue upper radiator hose and at least get an idea of how that top inlet sits in relation to the engine. ![]() ![]()
![]() Last edited by Handy_Cruiser; 28 Nov 2016 at 02:02 pm. |
![]() Quote:
I choose only one aspect to his post to respond to and added a little more having to do with fans. ![]() Well well another miss printed information slipped by the 'checkers". I have said so often over the years that many, many, many, after market application guides are not accurate. It is always better to contact the supplier or manufacture direct when there is any question about application.
To view larger pictures simply "click " on the picture! Dalai Lama "Share you knowledge. It's the best way to achieve immortality." ASE MASTER TECHNICIAN ![]() ![]() Last edited by NitroPT; 28 Nov 2016 at 02:19 pm. |
Yep, I was looking for confirmation that the TYC radiator or equivalent could be used even though it does not have a removable inlet. Taking off the intake manifold is not bad. Sounds like I can save some money. Thanks.
I have a 2004 turbolite and I replaced the oem radiator with an aftermarket with the fixed inlet almost exactly 1 year ago with no problems since. I've even removed the new one once to fix a couple of other things. The oem removable inlet was convenient, but since you need to take the whole radiator out anyway to replace it, you're not losing much.
Just make sure you get one that is compatible with the turbo, meaning the radiator needs to have the power steering coolant ports. The non turbo radiators don't have them. I removed the front end piece above the radiator, the grille, and the bracket behind it. Then loosened the hoses (the power steering hoses will be messy), the fan connections, then the bolts holding the radiator in place and lifted the radiator and fan out as one. I swapped the fan onto the new radiator, then put it in as one unit and replaced everything. Refilled the coolant, burped it, topped off the power steering, and was good to go. Last edited by Renegade; 29 Nov 2016 at 04:40 am. |
I swapped my 2003 GT radiator out with a TYC. I think mine cost $67 all in. I didn't have much trouble dealing with the radiator or the fan. I can't remember who changed my radiator out first, but I am at my third one without a removable anything. I'm not sure of any price difference, but I'd buy this one again. <knock wood>
2003 GT 5 speed 162,000 miles |
![]() Quote:
2003 GT |
My 2003 Dream has had a non-turbo radiator in it since I got it. I have no cooling problems with.
I have removed the turbo fan from my son's 2003 GT without removing the neck from the radiator with no big problems. We recently replaced his radiator with one from a 2004 Turbo I stripped a year or so ago. The radiator fit great and fan replacement was easy too. |
Tags |
oem, radiator replacement, removable inlet, turbo |
Thread Tools | |
Display Modes | |
03 turbo radiator fan | omnicrazy | Classifieds: Want To Buy | 16 | 31 Jan 2016 04:51 pm |
Turbo radiator fan | cncsparky | Tech & Performance Forum | 13 | 02 Nov 2015 10:05 am |
I bought a radiator for a non turbo pt and its for a turbo pt WILL IT WORK? | madmatt | Tech & Performance Forum | 15 | 17 Aug 2014 01:18 pm |
Radiator Fan for Turbo and Non-Turbo Question | DocLS | Tech & Performance Forum | 5 | 09 Jul 2012 09:28 am |
03 Turbo Radiator Replacement | hanks424 | Tech & Performance Forum | 15 | 29 Sep 2011 08:22 am |
