towing behind a RV
Old 21 Jun 2004, 07:46 pm
Default towing behind a RV
is anyone towing a manual PT cruiser 4 wheels down? are you accumulating miles of the odometer. and did you have the lights hard wired to a tow bar harness?
Old 21 Jun 2004, 10:52 pm
Since the speedo gear is in the tranny,yes you will pick up miles. Ever coast down a hill with the tranny in neutral? Did the speedo indicate how fast and how far you were going??Same difference. Just get wheel dolly and tow it.
Mike
Old 22 Jun 2004, 09:55 am
There is no speedo gear.
The VSS vehicle speed sensor requires power to the PCM and TCM to operate.
The old days of speedo gears and mechanical instrument clusters is long gone.
Old 22 Jun 2004, 10:24 am
Guess I'm showing my age, huh???
Mike
Old 22 Jun 2004, 12:21 pm
The wheel dolly is still a good idea. Little or no added stress on the front steering and drive train even if it's in neutral.
03 Inferno Red GT (Jun 03 build), 5-speed, leather, heat, 6CD changer, moonroof; winter wheels and tires for year 'round enjoyment; silencers removed, no other mods because I'm having more than enough fun with the power I have now!
Old 23 Jun 2004, 02:44 am
The PT (manual or automatic) will NOT accumulate mileage if the engine is not running while being towed four down. The PT is certified by Chrysler for four wheel down towing behind a motorhome ONLY with the manual transmission.
If you have the manual transmission all you need is the tow bar brackets and the light wiring (with diodes) installed on your PT and you are ready to tow.
I have the AutoStick so I had to add the Remco Transmission Lube Pump to make mine towable four down.
The PT makes a wonderful tow vehicle.
Old 27 Jun 2004, 08:13 am
jb jb is offline
I tow the manual GT cruiser all 4 wheels down. It does not add miles to speedometer and tows great. Yes, it is hardwired for lights,
Towing 2006 behind RV gruszka General PT Cruiser Discussions 5 15 Oct 2005 08:43 pm
Towing with the Cruiser jtdev General PT Cruiser Discussions 8 04 Aug 2005 03:00 pm
GT Towing Capacity??? jramosGT General Turbo Discussions 2 24 Apr 2004 04:05 pm
Towing question(s) westgate Tech & Performance Forum 4 23 Mar 2004 10:26 am
Disable Odometer for towing PT 2coolPT Tech & Performance Forum 14 07 Feb 2004 04:12 pm
