P0622 Code and Battery light on!!
Like Tree7Likes
  #21 (permalink)
Old 11 Jan 2017, 12:16 pm
Default Re: P0622 Code and Battery light on!!
Sorry I'm slow today. Am going out to do that now.
  #22 (permalink)
Old 11 Jan 2017, 12:17 pm
If I get no power with those grounded and it running, does that mean the alternator?
  #23 (permalink)
Old 11 Jan 2017, 12:42 pm
Ok. With the two grounded with it it off it reads 11.67 volts. When I fire it up it still reads 11.67 volts and drops slowly.
  #24 (permalink)
Old 11 Jan 2017, 01:05 pm
Forgive my stupidity, but what wires is this guy talking about?
Brad :
Here is what to do: Make sure the Dark Green/Orange wire has 12v when engine is running, that comes from the ASD Relay when engine is running.. Then check the Dark Green wire for ground.. This wire comes from PCM and is used to Ground the Alternator in order to charge.... If it doesnt have ground on that wire, Ohm it to PCM to make sure the wire is good.. If wire is good.. Your PCM is bad
  #25 (permalink)
Old 11 Jan 2017, 09:21 pm
It helps when you have a wire diagram of what you are working on.
New alternator not charging, how to check ECM? P0622 imalittleturt Tech & Performance Forum 20 19 May 2018 12:41 pm
Codes P0480, P0622 - seems erratic Jester1 Turbo Performance 10 26 Aug 2017 12:03 pm
battery light after new battery help! Annette Tech & Performance Forum 11 01 Sep 2016 11:03 am
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
