Tourng NA to turbo swap considered
Old 15 Feb 2017, 02:47 pm
Default Tourng NA to turbo swap considered
What am I in for?
Have an '04 with rod knock, found an '06 or newer complete car FS, looks like a touring as well, can't see the left side badge.
Is this doable?
Nick
Old 15 Feb 2017, 02:53 pm
Handy_Cruiser's Avatar
Default Re: Tourng NA to turbo swap considered
It would be very doable IF the second car was a 2005 or older. But because it's a 2006 2nd Gen PT, the PCM and wiring are different.
But the mechanical parts are almost all the same. The easiest was to do with what you have is probably to find a third 2004/2005 turbo PT donor car and get that PCM, wiring harness, SKIM unit, sentry key w/cylinder and the Autostick shifter and instrument cluster if it's a GT.
Right now, turbo PT's are only worth slightly more than N/A PT's. So if you had your N/A PT in good running condition, it's possible to sell it and use the money to buy a turbo model. That's the easiest and most cost effective solution. I've done this myself.
NA to Turbo Swap Breeeezin2000 General Turbo Discussions 30 07 Nov 2015 03:14 pm
Turbo Swap orbsoner Tech & Performance Forum 6 19 Jun 2015 01:50 pm
gt swap turbo 2.4 lets_go Canada PT Forum 0 01 Sep 2014 10:43 pm
03 Turbo swap Gurus into non turbo buick68 General Turbo Discussions 20 11 Mar 2014 03:58 pm
Turbo Swap out??? HAPPYDADDY76 Tech & Performance Forum 2 30 Jul 2008 07:06 pm
