Gearbox weird sound in 3rd gear PT GT
Like Tree11Likes
  #21 (permalink)
Old 19 Jul 2017, 06:31 am
Default Re: Gearbox weird sound in 3rd gear PT GT
Originally Posted by rambojoe View Post
drop the pan and check the magnet inside the pan or put one at the low point in case there isn't one... however keep in mind one bad gear usually means 2, or what ever gear it mates with on the other shaft and like mentioned, the forks..
Can you be a little more explicit? I do not understand what magnet it is, and I do not really know what to start with. Do i have to remove the gearbox from the car?
  #22 (permalink)
Old 19 Jul 2017, 07:24 am
rob302's Avatar
there is no pan.
as i mentioned before there is no reason to check or clean the magnet. you'll find a bunch of metal on it and it's all from when the trans was wearing in when new.
if you REALLY want to get to the magnet you'll need to remove the axles and transmission from the car. once you remove the trans and separate the case halves, the magnet will be the thing marked 10 in this diagram.
if you plan on going to all that trouble, i'd recommend also fixing third gear while you're in there.
Cristian likes this.
  #23 (permalink)
Old 19 Jul 2017, 09:08 am
I think I'm going to drive the car as it is. I'll try to get used to the noise of the third gear. When it finally broken, I'll change the transmission...
Turbodude06 and rob302 like this.
  #24 (permalink)
Old 09 Aug 2017, 07:57 pm
VNT's Avatar
VNT VNT is offline
ditch the ATF and put some Amsoil MTF or Redline MTF in it, might help reduce the noise.
ATF is a poor compromise in these gear boxes, chosen to reduce parts count on production line and to improve shifting in cold climates.
The syn MTF will protect the gears and bearings vs the thin ATF, give it a try if you can source it.
VNT
89 Shadow ES 2.5 T2 +20's A555 sold
90 Daytona ES 2.5 T1 A523
90 Datyona Shelby VNT needs work
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
03 PT GT Black 5 sp Stg 1
05 PT GT Silver 5 Spd Conv
3rd and 5th gear jumping out transmission gearbox problem denkara Tech & Performance Forum 5 26 May 2015 03:23 pm
Weird gearbox sensor issue? Garya1682 Europe PT Forum 6 23 Aug 2013 08:23 am
weird sound on hwy woahgt Turbo Wheels/Suspension/Handling 4 02 May 2013 04:43 pm
Weird sound just disappeared? Undergfx General Turbo Discussions 6 28 Apr 2010 10:49 am
Strange, Weird sound PTNoob01695 General PT Cruiser Discussions 2 15 Sep 2009 08:56 pm
