Gearbox weird sound in 3rd gear PT GT
Like Tree11Likes
Old 31 May 2017, 01:26 am
Default Gearbox weird sound in 3rd gear PT GT
My 5 speed manual gearbox makes a weird noise when driving in 3rd gear, between 2000 and 4000 rpm. It's a metallic sound, which is only heard when I accelerate. If I raise my foot from the gas, the sound stops. It is only heard in 3rd gear and only when I accelerate over 2000 rpm. The sound is sharpened as if rubbing two metal parts on each other. The sound increases in intensity at the same time as the acceleration I put the atf4 in the box, 2 liters, I'm not sure if it's the right amount. Has anyone ever encountered this problem?
Old 31 May 2017, 06:46 am
rob302's Avatar
Default Re: Gearbox weird sound in 3rd gear PT GT
Does the car pull into and out of third easier than other gears? As in is there less resistance pushing pulling the shifter
Old 31 May 2017, 12:49 pm
No. It is only the noise.
Old 02 Jun 2017, 04:53 am
_PTGT03's Avatar
most likely to be an exhaust component like a loose catalytic converter, heat shield or other metalic object. it's just being 'tuned' to make noise at the exact frequency.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 02 Jun 2017, 03:58 pm
I don't think so...if i press the clutch, the sound disapear...the sound appear only when the car is moving, only in 3rd gear...i think is something in the gearbox, a bearing or something...
Does somebody knows of the non turbo 2.4 pt gearbox is the same like the one on gt?
Old 02 Jun 2017, 04:29 pm
Fk5 Fk5 is offline
It's not. The GT uses a Getrag 288. I believe the non-turbo uses a New Venture 350. I believe it is the same trans used in the Neons. The SRT4 Neon uses the New Venture 850. Not sure about swapping them, but it is probably more trouble than it is worth.
Cristian likes this.
2003 GT 5 speed
162,000 miles
Old 04 Jun 2017, 05:16 pm
I've notice that the 2.2 diesel engine, use the same getrag288 gearbox, but with bigger ratio in first and second gear. The 3rd, 4th and 5th are almost the same. What will it be if i'll put a 2.2 diesel gearbox on my 2.4 turbo pt?
Old 05 Jun 2017, 08:05 am
Fk5 Fk5 is offline
I have no idea, but as a long time GT owner/driver, I can tell you that the only things I would change about mine would be to put a taller O/D on it for MPG. the mileage takes a pretty steep dip as you start getting up around 80 (and over). I guess they wanted closer ratios because compared to the super tall o/ds in some of my cars (Daytona for instance) the PT still pulls pretty good in 5th. Personally, I would rather just have 5th be strictly for gas mileage and downshift if I need/want more.
Only other things I've had issue with are the multi-layer (whatever it is called) flywheel coming apart at 100,000 miles and making it difficult to shift and impossible to pull out of gear.
There seems to be an issue with my throwout bearing too. It seems like all my cars get this. Makes a mechanical noise in neutral, put the clutch in and it disappears. My Dad and I have shared a bunch of cars over the years, they have all gotten some version of this noise, but they have gone tons of miles (several over 150K) and it hasn't seemed to hurt anything. His SRT8 was making it from almost new and the dealer basically convinced him "it was normal." I guess we do something that causes it, but we have done most of our driving in NYC, so way more shifts per mile than your average driver and <knock wood> the only major issues have been the flywheel on the PT and several $18 clutch cables on 2.2 T1s.
Turbodude06 likes this.
2003 GT 5 speed
162,000 miles
Old 05 Jun 2017, 09:26 am
Handy_Cruiser's Avatar
First, I've never played with a Getrag 288S. But I have worked on lots of manual transmission from years gone by.
There's a chance this is just a misaligned shifting fork. It's possible that the shift linkage bushings are worn and causing a misalignment while in third gear. This is something easy and inexpensive to check out before going into the transmission shop. I'd inspect and possibly change out these inexpensive and often worn bushings before taking my PT to a shop.
rambojoe likes this.
Old 05 Jun 2017, 10:22 am
Turbodude06's Avatar
Have you tried just changing the trans fluid first?
Mine make a little noise in 5th while cruising too. But my exhaust is so loud now I can't hear it lol!
2004 PT GT 5-Speed! Project "THE RIDDLER"!!!
http://www.ptcruiserlinks.com/forum/...t-5-speed.html
3rd and 5th gear jumping out transmission gearbox problem denkara Tech & Performance Forum 5 26 May 2015 02:23 pm
Weird gearbox sensor issue? Garya1682 Europe PT Forum 6 23 Aug 2013 07:23 am
weird sound on hwy woahgt Turbo Wheels/Suspension/Handling 4 02 May 2013 03:43 pm
Weird sound just disappeared? Undergfx General Turbo Discussions 6 28 Apr 2010 09:49 am
Strange, Weird sound PTNoob01695 General PT Cruiser Discussions 2 15 Sep 2009 07:56 pm
