oil flow to turbo
Old 15 Jul 2017, 04:11 pm
Default oil flow to turbo
hey guys, has anyone felt compelled to check to ensure oil is getting to the turbo?
the reason is because I hear a loud squeal and it sounds like it is coming from the turbo, and not the belts.
I just bought the car, drove it home, heard the squeal, saw glowing turbo and replaced the turbo. have it in and all connected, the turbo spun up like it is supposed to and started squealing.
We immediately shut it down, we followed all of the instructions for installed the turbo, added 60 ml of oil into turbo spinning it to prime the turbo... so to hear a squeal, sounds like metal on metal, scares me. I would like to ensure the oil is flowing properly.
is there a way to check oil flow? I replaced the feed line and ensured the return line is clear. any insight would help.
thank you, Blaze
Old 15 Jul 2017, 06:30 pm
Default Re: oil flow to turbo
If you replaced a new oil line as you should have done than you WILL have oil flow at least to the Turbo...no question. If you did not and reused the oil line... ....then there is no easy way except to to disconnect you coil connector,disconnect the oil line at the Turbo and then ignition start the rotation of the engine for about 3-10 seconds only or until you make a mess. If no oil sprays after no more then that long 10 seconds you have a problem.
Old 16 Jul 2017, 05:31 am
thanks bro... I replaced the line. I was just curious if I had an oil pump problem. i just didn't want to make too much of a mess.
EGR flow 400 2k1PT Tech & Performance Forum 20 01 Jan 2014 08:46 pm
Against the Flow! Jimmy2011 Turbo Performance 2 07 Feb 2012 12:39 pm
No air flow on '3' Ela Tech & Performance Forum 2 18 Sep 2010 02:34 pm
Turbo Down Flow monk General Turbo Discussions 10 13 Jun 2007 10:10 pm
turbo tech flow chart.... Punch General Turbo Discussions 1 30 Dec 2003 05:48 am
