Spark Plug Help needed
Like Tree4Likes
  #11 (permalink)
Old 29 Aug 2017, 02:31 pm
Default Re: Spark Plug Help needed
Nitro I didn't think the PT had a waste spark system, but after checking the service manual, It is. It is two coils in the pack that fire paired cylinders together. 1 and 4 as well as 2 and 3 at the same time. So yes, double platinum spark plugs would be useful on the PT Cruiser. As for your .042 spark plug gap.... Definitely gonna give that a shot.
2004 Stage 1 GT Manual, Miles: 95k
Lowered Suspension, Sway bars, sound system W/Mopar Sub, LEDs, Debadged, Hydraulic hood struts, Hybrid BOV, (pending install): Hard pipe intake tubing, Needswing 3 inch downpipe (with cutout), 3inch O2 elbow, and Magnaflow catback.
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
  #12 (permalink)
Old 29 Aug 2017, 02:37 pm
Rule No. 1 of plugs is: THE WORSE THE IGNITION YOU HAVE, THE MORE CRITICAL IS THE PLUG SELECTION
If you've got a OEM ignition many times posted information about its level of performance is from people who have never really seen what an ignition system does above 3000 RPM and assume to much. Perhaps some should be picking out platinum plugs to make up for the weak ignition.
With a good ignition system THERE WILL BE NO MEASURABLE DIFFERENCE IN POWER, MILEAGE OR PLUG LIFE BETWEEN THE NEAR RIGHT AND PERFECT PLUG CHOICE.
  #13 (permalink)
Old 29 Aug 2017, 02:39 pm
Like I always love to tell people.
For this... It will work, until it doesn't.
Once it works.... can't get any better.
  #14 (permalink)
Old 29 Aug 2017, 02:56 pm
LOL I have already built a 4 coil system for myself and another PT Cruiser owner...and I also have used waste spark system on another platform Chrysler engine for years with a "knock your socks off" ignition system.
BTW most all my PT Cruiser 1/4mile passes (almost 80) are on #470's with a 75 shot of N20.
The platinums are a waste of money IMHO!
Hey its your money $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
  #15 (permalink)
Old 29 Aug 2017, 02:58 pm
I was saying the Double Plats have some use if your intent is for longer life on a single set of plugs.
I run the #470 in mine. I wish I had a 75 shot of N20 in my car.
NitroPT likes this.
  #16 (permalink)
Old 29 Aug 2017, 04:01 pm
I run the Champion Double Platinum #7570 in mine. Put them in at 60K and have 124K now. Starts at first turn every time, smooth idle and goes right up to red line if needed without hesitation.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
  #17 (permalink)
Old 29 Aug 2017, 05:01 pm
Fk5 Fk5 is offline
I think my car had the original plugs on it until last year. Until then, it started immediately, idled smoothly and would pull great, though I generally stay pretty far below redline. I changed them when I started chasing my misfire. One had a .8+ gap. Had to double up on the feeler gauges to measure it. The plugs weren't causing the misfire.
2003 GT 5 speed
162,000 miles
  #18 (permalink)
Old 29 Aug 2017, 05:22 pm
ok...now go and try and stomp on your throttle from a standing stop and run it to red line and see what happens in each gear but we will leave out overdrive, lets say 1st -3rd.
ooooooooh.............. a little different like WTF is going on, why is it running so badly...???
  #19 (permalink)
Old 31 Aug 2017, 08:37 pm
I've always been an NGK guy myself. Currently running 4306 , 5 on heat. And 44 gap. Thinking I might try the champs at 42 next time I pull plugs.
I'm thinking heat range changes would be more noticeable difference than plug type changes. ..if that makes sense. ..
I guess what I'm trying to say is maybe you would notice a heat range change more than you would be able to notice a difference from platinum to double platinum? If you jumped more than just 1 or 2 on heat, but y would you do that anyway lol ??
03 gt 5 speed Stage 1
Whoever says "There's no replacement for displacement " obviously underestimates RPM
Tags
2005 automatic, spark plugs, turbo gt
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto Vendors & Buyers Forum 7 23 Jan 2017 03:17 pm
Spark Plug Gap NavyCruiser Tech & Performance Forum 10 18 Jun 2011 09:27 pm
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
Spark Plug GAP duffner General Turbo Discussions 11 16 Mar 2008 12:55 pm
Spark Plug Gap sakigt Turbo Performance 8 09 May 2003 03:47 pm
