Airbag Cover Replacement
  • 1 Post By KalebSikora
Old 29 Aug 2017, 07:29 pm
KalebSikora's Avatar
Default Airbag Cover Replacement
I recently removed the emblem from my PT and was going to replace it with one I took off another PT from the junk yard. Mine has had a broken right wing for years and I was sick of it. However, when I went to remove mine and put the new one in I somehow broke both! Now the cover in my PT is all scratched.. Is the a way I can get a new cover and still keep my airbag to save money?
Old 09 Sep 2017, 02:38 pm
Default Re: Airbag Cover Replacement
Bump.
So instead of replacing the whole cover, could I just replace the emblem? I found a listing on eBay here that provides the emblem and the clips. It looks exactly like my old emblem. Can I possibly remove the airbag without having to replace it or the clockspring?
Old 09 Sep 2017, 04:18 pm
Handy_Cruiser's Avatar
Yes. The airbag is on the front side of the steering wheel. The clockspring is right behind the steering wheel. The airbag will just unplug once loose. But you can likely just glue a new emblem on the airbag while still in place.
Old 09 Sep 2017, 04:20 pm
Sinbad's Avatar
Not sure how the emblems come off - have you tried using dental-floss? It's what peeps use to get decals off the body for spraying. Might work in this case and you will be unlikely to trigger the airbag with it. Or do you mean get the boss off the wheel? If so I'm almost certain you'll be into the usual raft of problems that come with jigging about with airbags.
Old 09 Sep 2017, 05:09 pm
Yeah I'll just glue it I guess. Any specific glue recommendations?
Handy_Cruiser likes this.
Old 09 Sep 2017, 05:37 pm
3M Plastic Emblem and Trim Adhesive
Old 09 Sep 2017, 05:40 pm
Thanks. I'll get the glue then.
Old 13 Sep 2017, 02:48 am
Well this is how it turned out. Not bad.
Cover for Airbag. Mideskar General PT Cruiser Discussions 5 21 Feb 2015 08:26 pm
Cluster cover / airbag cover pluminator Classifieds: Want To Buy 0 22 Apr 2013 11:24 pm
Airbox, airbag cover, and gauge cluster cover needed cruisin03pt Classifieds: Want To Buy 5 26 Nov 2012 12:26 pm
WTB-Pass Airbag cover MYREDPT Classifieds: Want To Buy 0 17 Jun 2004 10:34 am
