Air bag Light and code P0480
Old 30 Sep 2017, 06:48 pm
Default Air bag Light and code P0480
Recently bought a 03 Turbo everything was fine till the battery went dead. Replaced the battery and after replacement I now have a Air Bag light on. And the Rad. Fan no longer works along with code P0480 .Everything was fine until battery replacement. Doesn't make sense.
Anyone have any ideas
Old 30 Sep 2017, 10:39 pm
Default Re: Air bag Light and code P0480
I would suggest checking the ground wires going to the driver's side inner fender. Your ground might be weak.
Old 01 Oct 2017, 02:22 pm
Thanks Steve,
That was my first suspect and it did fix the Fan Problem and code.
Still have Air Bag light will see if garage at work has a scaner that can access the SRS system.
2006 2.4L non turbo P0480 kcbuechler General PT Cruiser Discussions 28 29 Jun 2017 11:35 am
'05 throwing P0480 & P0481 after AC job...? AcIdBuRn02ZTS General PT Cruiser Discussions 11 22 Jun 2017 08:43 am
P0480 need help asap 203turbopt General Turbo Discussions 7 25 Sep 2012 04:49 pm
need some help with another error code P0480 on a 2007 pt cruiser 07ptcruzin Tech & Performance Forum 4 11 Nov 2008 06:27 pm
Computer code # P0480 MINIHEMI46 General Turbo Discussions 10 17 Jul 2007 04:04 pm
