03 PT Cruiser Turbo GT Power Steering Pump Removal/Install
Old 09 Oct 2017, 08:08 pm
Default 03 PT Cruiser Turbo GT Power Steering Pump Removal/Install
Hi everyone. Can anyone provide either a semi-detailed description, link, or video on removing the power steering pump (with/without reservoir?) by simply removing the mounting bracket and not the laborious step-wise method of having to remove the fan/radiator, as I've heard of a video that indicates it can be done (but the video doesn't show the process) as well as a couple threads mention that it can be done?
Thanks
Old 10 Oct 2017, 07:21 am
Default Re: 03 PT Cruiser Turbo GT Power Steering Pump Removal/Install
I don't know as I never had to do it to mine, but have you tried looking on youtube?
Ignorance can be educated, crazy can be medicated but there's no fixing stupid!
Old 10 Oct 2017, 12:08 pm
_PTGT03's Avatar
remove the right tire, fender linder, and remove the right headlight. from there you have access and room to see what you're doing
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 9800i and Escort Shifter ZR4, front facing traffic camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Electric valve actuated Y-pipe with catalytic converter delete. issues: lower than expected boost, PCM in progress of replacement and tune with Syked Software
turbo power steering pump leak 2_cruisers Tech & Performance Forum 1 12 Feb 2017 08:15 pm
03 Turbo Power Steering Pump chromer don General PT Cruiser Discussions 12 11 Nov 2016 06:59 pm
Turbo Power Steering Pump Reservoir Ikster Tech & Performance Forum 0 17 Oct 2015 02:04 pm
need 2003 gt turbo power steering pump and res zipps Classifieds: Want To Buy 1 12 Apr 2015 07:52 pm
Power Steering Pump N/A vs. Turbo meder2487 Tech & Performance Forum 3 13 Jan 2011 10:12 am
