2003 GT turbo exhaust
  • 1 Post By _PTGT03
Old 17 Oct 2017, 06:56 pm
Default 2003 GT turbo exhaust
2003 GT turbo exhaust upper bolt. The nut has some kind of plate welded onto
it. It keeps turning & i can't get the bolt out. Any ideas / suggestions?
Thanks Larry
Old 31 Oct 2017, 10:03 am
Default Re: 2003 GT turbo exhaust
You gotta be a little more descriptive than that. How about a pic from service manual?
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 31 Oct 2017, 09:36 pm
_PTGT03's Avatar
this shouldn't be something that's too hard to figure out.
the very top bolt has a wingnut extension welded on there so that you don't need to hold it with a wrench since there's limited access. if everything is mechanically correct with respect to being factory as is, if you're removing the bolt the right way, it should come off. if it keeps turning, take a die grinder with a cutoff wheel and zip off the bolt head. knock out the stud and see what's going on. the nut could be seized on or something of the like. they should be 13mm and nut heads
Handy_Cruiser likes this.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
'03 Turbo Exhaust timing unclemeat Turbo Performance 29 25 Aug 2014 01:56 pm
2003 GT Exhaust fy9-03pt Classifieds: For Sale/Trade 5 06 Jul 2013 09:30 pm
SRT-4 exhaust on Non-turbo PT? fox50h Tech & Performance Forum 8 14 Jan 2011 07:42 pm
SRT 4 Exhaust on a PT Turbo Convertible mopar1cjh PT Cruiser Convertible Forum 1 21 Feb 2009 03:40 am
Megaflow exhaust on turbo Jimbo General PT Cruiser Discussions 6 23 Jan 2004 09:23 am
