TURBO PCV hose part number
Like Tree4Likes
Old 23 Oct 2017, 11:57 pm
_PTGT03's Avatar
Default TURBO PCV hose part number
so, on rock auto they listed a wrong part and I ordered it GATES EMH200 . so it's for the non turbo engine. figures. trying to decide if its worth returning or emailing the support at this time.
does anyone know the right hose part number ? i have a photo above. the lower hose is correct.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 9800i and Escort Shifter ZR4, front facing traffic camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Electric valve actuated Y-pipe with catalytic converter delete. issues: lower than expected boost, PCM in progress of replacement and tune with Syked Software
Old 24 Oct 2017, 12:22 am
rckstein's Avatar
Default Re: TURBO PCV hose part number
According to the '03 Parts Catalog that I have, the p/n is 4884288AC, but in searching online for that part, it appears to have been superseded by 4884702AB. Sometimes when searching for the parts, you can include or delete any leading 0, because some websites include it, when others don't:
https://www.amazon.com/Mopar-4884702...OPAR+4884702AB
If I were you, call your local dealership and with the VIN, they will be able to tell you the correct and current part number for the part you need.
As far as the RockAuto error, I checked their website and their electronic catalog lists the same Gates EMH200 PCV hose for yours and my PT, and mine is an NA and they are 2 different hoses.
IMO, you should contact the RockAuto Customer Service, explain the situation and the error in their electronic catalog, and they should provide you with a return shipping label to cover the return for their error.
_PTGT03 likes this.
'06 Touring Edition NA Automatic
151k Miles / Electric Blue Pearl
USMC '82 - '93
Old 24 Oct 2017, 12:38 am
_PTGT03's Avatar
i think i will call up my dealer and order this part, or just use the industrial catalogue and use 3/8 fuel line hose and some brass fittings and a check valve. seems like the male thread size is 3/8-18 national pipe into the valve cover for the check valve. i will order a 3/8 male to 1/4 female inline check valve, 1/4 npt with 3/8 hose bead end, and a 90 degree male elbow 1/4 npt and get another 1/4 npt 3/8 hose bead end. then i will use 3/8 fuel line for the hose.
Old 24 Oct 2017, 12:48 am
rckstein's Avatar
i think the updated part number is mopar 4884702AB
I think so too, but you could confirm that with your local dealership.
Or you could also try this website:
https://www.quirkparts.com/
Enter the PT VIN in the large search bar at the top, then that should filter the parts for your PT.
USMC '82 - '93
Old 24 Oct 2017, 01:27 am
Tucker05's Avatar
I just ordered the same part from Rock Auto. And had to return it. Customer service representative said that it was the correct part and it should work. Did more research and found it will but with a totally different engine. Mainly for a early Gen Neon. Hopefully I will be able to return it and get a refund.
Old 24 Oct 2017, 01:38 am
rckstein's Avatar
According to the Gates website, they don't even make a PCV hose, or any other parts, for the Turbo PT, only the NA engine is listed:
http://www.gatesracing.com/parts
In that case, the RockAuto website would be in error. It's their information that they are disseminating and if it's in error, they should pay for the return shipping of any product that was shipped in error.
This is one reason I make all my online purchases via PayPal as they have a very good, and easy to use, dispute resolution department.
USMC '82 - '93
Old 24 Oct 2017, 01:53 am
This is why I don't order from RockAuto unless I have purchased that item already. The customer service department is not the same as it used to be and more members are complaining.
Old 24 Oct 2017, 01:03 pm
_PTGT03's Avatar
The support team member got back to me. I'm very satisfied with how this issue was dealt with. The paypal refund for the part was issued immediately, and I can just move on and not have to worry about returning this.
Good Morning,
I'm sorry to see EMH200 was incorrect for the vehicle your repairing. When I contacted Gates regarding the difference I was informed to remove this part number from turbo PT Cruisers until they can look into the difference more. It's not cost effective for us to recover this part, you will not need to physically send it back. A refund will process in the next 1-3 business days back to your PayPal account, once this takes place we'll email a notice of refund for your records. I'm sorry for the delay in repair & for any inconvenience this has caused.
Thank you,
Jeff
rckstein and Tucker05 like this.
Old 24 Oct 2017, 01:06 pm
Tucker05's Avatar
That is good. I hope that they really look into the catalog now that 2 orders in a 2 week time frame have been incorrect. I guess we are both headed to the dealer to get the correct part.
rckstein's Avatar
You should see the above reply and do the same, and should hopefully get the same result
USMC '82 - '93
Need help with a part number ? (2) red98gt General PT Cruiser Discussions 1 29 May 2017 01:01 pm
PCV Hose Part NUmber?? timjor Tech & Performance Forum 8 25 Oct 2015 02:05 am
Part number? Mideskar Wheels, Tires, Suspension 1 21 Mar 2015 06:02 pm
Help with a part number? thesameguy Tech & Performance Forum 4 27 Nov 2012 08:13 pm
Need Help With OEM part number csd PT Cruiser Convertible Forum 8 05 Nov 2011 11:21 pm
