2003, hesitation, missing, between 1800rpm and 2400 rpm
Like Tree5Likes
  • 1 Post By myckee
  • 1 Post By rob302
  • 2 Post By _PTGT03
  • 1 Post By chuzz
Old 13 Nov 2017, 12:32 am
_PTGT03's Avatar
Default 2003, hesitation, missing, between 1800rpm and 2400 rpm
Very strange and specific problem, it was repeatable with the correct circumstances. If I was to give anywhere less than 100% throttle, between exactly 1800 and about 3000 rpm there was just a complete loss of power, the car would jerk violently. I had to call over a second person to come in and give an opinion. Strangely, at exactly full throttle, there was no issue. So the car was completely undriveable. No DTCs, and the live stream data seemed completely usual. I initially though it was a camshaft position sensor or something of the like.
I swapped out my stage 1 computer and re-installed the stock computer and immediately all the problems went away. I guess my computer just failed, suddenly, and exhibited a very strange problem !
and here's a video of the symptoms.
https://photos.app.goo.gl/OMV3sM6JwDL8K8t63
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 9800i and Escort Shifter ZR4, front facing traffic camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Electric valve actuated Y-pipe with catalytic converter delete. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 13 Nov 2017, 07:06 am
Default Re: 2003, hesitation, missing, between 1800rpm and 2400 rpm
Before I read the last sentence, where the problem went away with the installation of the stock ecu, I was thinking it sounds like a defective coil pack. I have heard of a few instances where they don't generate a code and the car has virtually identical behavior.
Well, if it was me, before I wrote off that ecu I would experiment by swapping the coil and trying it again. These cars don't like certain aftermarket coils, so I would try a stock one.
Handy_Cruiser likes this.
Old 13 Nov 2017, 09:35 am
rob302's Avatar
Possible something with closed loop operation, but open loop still ran fine. Did it run fine before it warmed up before, it would enter closed loop?
_PTGT03 likes this.
Old 13 Nov 2017, 12:35 pm
_PTGT03's Avatar
Who knows. Since I removed my CAT, I have the two sensors getting a code, however there should be no problems with this circumstance as it was working fine initially for a month since I removed the cat. And, the stage 1 computer worked fine for a year since I bought it used.
With all my automotive experience I've never seen a truely faulty ignition coil except for one on a cavalier that would fail after the engine was washed and water got onto it, until it dried for a few hours.
I did have an intermittent misfire one time and it was solved by replacing a coil control wire from the wiring harness.
Old 13 Nov 2017, 03:25 pm
Fk5 Fk5 is offline
That's interesting because it was my first thought when reading Mykee's post. Might be worth a look.
2003 GT 5 speed
162,000 miles
Old 13 Nov 2017, 04:28 pm
_PTGT03's Avatar
no, that's complete nonsense. my coil is OEM, it's new. the problem here is solved and determined as a defective computer. that's all.
Old 14 Nov 2017, 10:39 am
So, what is your next step? Buy another Stage 1? What will you do with the junk computer?
Old 15 Nov 2017, 11:05 pm
_PTGT03's Avatar
i may decide to have it repaired.
i have another computer at Sykes Tuning. it's been sitting there a couple months waiting until i get the handheld tuning package.
Old 17 Jun 2018, 06:07 pm
_PTGT03's Avatar
Update: The issue was caused from a failing upstream oxygen sensor. Replaced with Bosch part number 15510 and all the symptoms stopped. The issue was in fact due to closed loop operation breaking down completely, as the feedback from the failing oxygen sensor was completely scrambled. I also considered the throttle position sensor as a potential issue but I had observed a linear signal voltage output from driving the throttle plate.
rob302 and oldthom like this.
Old 18 Jun 2018, 07:20 am
Seems like Rob had the right idea. Kudos, Rob!
_PTGT03 likes this.
Farts are just ghosts of the things we eat.
Looking for a hifonics brutus 2100 or 2400 Darkside7789 Classifieds: Want To Buy 2 10 Aug 2012 06:05 am
Hesitation rchapman20 Tech & Performance Forum 4 21 Apr 2012 07:41 am
Hesitation DukeofWagner General PT Cruiser Discussions 1 26 Oct 2008 06:29 am
Get rid of the WOT hesitation... Cal Cruzer Turbo Performance 2 15 Jun 2004 01:02 pm
hesitation JST CRZN Tech & Performance Forum 6 23 Oct 2001 04:49 pm
