Turbo Oil return line leak!
Old 14 Jan 2018, 12:42 am
brian2002utd's Avatar
Default Turbo Oil return line leak!
Thanks for all that helped me get my oil feed line leak fixed. However oil is still leaking from somewhere on the turbo and dripping down the intercooler pipe. The owner I bought this car from a few weeks ago had recently rebuilt the turbo and since they botched the feed line I would not be surprised if the return line needs work. Could use a little expertise on this one. How do I fix it?
Old 14 Jan 2018, 07:48 pm
Default Re: Turbo Oil return line leak!
Its hard to tell where the oil is coming from as I havent driven the car much since fixing the feed line so some of that oil is probably from when the feed line was leaking all over the place. Where ever it is leaking from it is running down the intercooler pipe but in my picture it looks like the return line would not leak on to that pipe. I've checked busted PTs instructions on how to get to the return line fitting but may add some UV dye to verify where the oil is coming from first.
Old 14 Jan 2018, 11:59 pm
_PTGT03's Avatar
looks to me like there's a missing bolt holding the return line. there's two bolts if i can recall that hold it in, along with gasket. once that's set up, reinstall the bolts and torque to the factory spec of 105 in-lb . if you don't have a replacement gasket, get the gasket card material in a 6x6" sheet or what have you from a parts store, trace the mating surface of the tube and cut the outline and then cut holes for the bolts in the gasket.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 15 Jan 2018, 12:25 am
Thanks for taking a look PTGT03. I went back and took a closer look at the photos I took. I can see the other bolt in the full resolution copy. However, in my closer inspection I also believe you are correct on the new gasket/retorque. I think there is a good chance those bolts are not set to torque. The feed line definetlely wasn't which is what I fixed last week! I honestly dont think the original owner had a torque wrench! I checked the wheel lugs the other day for good measure and they were all over the place! Those oil return line bolts look like they are going to be fun to get to!!
Old 15 Jan 2018, 12:33 am
Old 06 Feb 2018, 12:47 am
Turned out to be the oil pressure sending unit.I had to take her in for an exhaust leak that was beyond my mechanical abilities and went ahead and let my mechanic take a look at the oil leak. It was a less than $300 repair. Not too bad. They recommended a muffler shop for the exhaust as they only use Chrysler OEM parts. Maybe I will put a Borla or Flowmaster on it
found my boost leak! its on the oil return line of the turbo. is this normal? ian18206 Turbo Performance 2 21 Jun 2016 02:00 pm
Return line leak, needs to be replaced Shoky76 General Turbo Discussions 3 30 Apr 2016 12:28 pm
Turbo oil return line leak littleblueGT General Turbo Discussions 7 24 Apr 2016 10:29 am
How to access bolts of turbo oil return line MarcoB General Turbo Discussions 16 17 Dec 2013 02:15 pm
Impending turbo doom, or just a clogged oil return line causing whine and smoke? icezebra Turbo Performance 5 05 Oct 2008 04:14 am
