radio dead
Old 11 Jun 2018, 01:56 pm
Default radio dead
I accidently used my Jeep key in the Cruiser ignition switch which made the radio go dead. anyone know why and how to fix?
Old 15 Jun 2018, 11:49 pm
Default Re: radio dead
maybe reset the ecu. unplug the battery for a while.
Old 16 Jun 2018, 09:51 am
On a PT Cruiser this only disconnects 12 volt power supply....nothing more. Its not the 90's and OBD1 Diagnostic systems anymore.
PT Cruiser use either 1st Generation OBDII or second generation CAN-bus both ECU will hold information even if the battery or 12 volt power supply is disconnected. You can not re-set any ECU operation or security setting disconnecting the power supply. This will remove the caution lights on the dash which may have lead many to believe that the ECU was re-set. Using a good shop quality Diagnostic Scanning Tool can show none resolved issue still in the monitors or as a stored DTC.
Old 25 Jun 2018, 08:35 am
Nitropt, Is there a fix for that???????????
Why would vent selector change the radio station? (aftermarket radio) Spaz Sound and Security Forum 11 08 May 2016 01:10 am
PT 2002 radio dead raconi General PT Cruiser Discussions 5 14 Jun 2014 05:15 pm
dead battery foglights and radio code doodlepip Tech & Performance Forum 2 18 Mar 2014 03:17 pm
Radio's Dead KYCruizin General PT Cruiser Discussions 10 03 Jan 2011 03:17 am
