Turbo Pop Noise??
  • 1 Post By chuzz
Old 02 Aug 2018, 07:53 pm
Default Turbo Pop Noise??
So the local garage said that the car needs a new turbo... this is what happens when it starts up... and on the way to the garage it happened a couple times. I drove it because I thought it was the starter possibly.
They wanted close to $3000 for parts and labor, but I have seen reman kits for $500-700. What is the replacement like?
https://youtu.be/KXXJzGa658w
Old 03 Aug 2018, 07:39 am
Default Re: Turbo Pop Noise??
That just sounds to me like you've got a vacuum leak somewhere. I'd go get another opinion. AFTER I checked my vacuum lines first. And $3,000?? Are you kidding me? You can get another PT for less than that. Run, don't walk away from that shop. Heck, someone here probably has another turbo that you could buy a lot cheaper than that.
Handy_Cruiser likes this.
Hey, hey I wanna be a rock star.
Old 03 Aug 2018, 01:37 pm
I can honestly say I have never heard that noise. It's definitely not work 3k to fix.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 03 Aug 2018, 02:26 pm
I am thinking that maybe the blade is getting stuck or something. I am going to pull the turbo myself (strongly mechanically inclined and have tools like a mechanic, just no lift).
I when it runs it sounds like a bearing has gone, but it is a weird sound and it sounds mechanical. I wont pay for the new turbo, but if I could get away with a new cartridge (saw this in another forum post) I could keep it running for awhile, especially since its a summer car only.
Old 05 Aug 2018, 06:47 am
Do a search here. Lots of good info about the turbo repair/replace. You might get by with just replacing the bearings. You can check the bearing play by putting your finger on the impeller and seeing if it has side to side or up and down movement. Then you'll know what you have to do.
Old 05 Aug 2018, 07:12 am
Sinbad's Avatar
If you've got going the whole hog in mind anyway - you have nothing to lose by trying the old "Fill it with Oven Cleaner" trick first.
It quite often sorts em out - and if it doesn't, you've lost nothing but a can of oven cleaner
_________________________________________
'07 2.2 CRD
Bollocks to Brexit
Turbo noise? StealthyK General Turbo Discussions 11 10 Apr 2012 12:07 pm
Turbo howling noise tbocruiser Tech & Performance Forum 0 06 Mar 2009 06:55 pm
Turbo noise sawdust123 General Turbo Discussions 19 28 Mar 2005 01:35 am
Turbo Noise lip General Turbo Discussions 5 22 Jul 2004 04:10 pm
Turbo "noise" bigguigt Turbo Performance 8 18 Mar 2004 08:47 pm
