Slave cylinder
Old 01 Dec 2018, 01:04 pm
Default Slave cylinder
About a month ago, I had to take the transmission out of my car to replace a fitting on the slave cylinder. After I got the car back together the whole car would start to shake if I didn't let the clutch out slowly. I just took the transmission out again and the spring on the slave pushed out. The spring is not connected to the slave or the circle piece that pushes on the clutch.
Does this mean that slave is bad or can I just try to push it all back on together?
Old 04 Dec 2018, 04:45 pm
Default Re: Slave cylinder
Did you press the slave while the clutch was not installed in the vehicle? Did you reverse bleed all the air out?
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 05 Dec 2018, 04:21 am
Chaz; the slave cylinder and throw out bearing are a [sealed] combined unit on diesel and turbo PT's. [2006 info and likely all years]. Your old one is bad if it is separated. NEVER push on the clutch pedal unless the bearing/slave assy. is fully installed in the vehicle.
Concentric Slave Cylinder quest Tech & Performance Forum 0 11 Mar 2016 12:23 pm
Slave Cylinder Replacement LowLowPT Tech & Performance Forum 3 10 Jun 2015 10:54 am
Slave cylinder connection dckoone Turbo Performance 0 23 Aug 2011 08:40 pm
03 slave cylinder problem fuhr31 General Turbo Discussions 2 06 Dec 2010 07:40 pm
clutch and slave cylinder chops660 Tech & Performance Forum 2 21 Nov 2007 01:32 pm
