won't crank when hot 2003 turbo
  • 1 Post By VsandFords
Old 07 Jan 2019, 01:47 pm
Default won't crank when hot 2003 turbo
I have replaced ECM, ignition switch, starter.
Old 07 Jan 2019, 03:10 pm
VsandFords's Avatar
Default Re: won't crank when hot 2003 turbo
More information please. What are the symptoms? Does it spin and not start? Does it make a noise, like a click and not spin? Does it do nothing? Have you checked fuel pressure or spark when it doesn't start? Is the CEL on?
Old 07 Jan 2019, 04:50 pm
I would do a load test on the battery. Verify your charging system is putting out 14 volts.
Does the red security light come on when it stops cranking?
If this is no red security light I would suggest checking to see if you have 12 volts going to the starter from the ignition switch when it is hot.. If no 12 volts I would check to see if you have 12 volts going to the starter relay after you pull the starter relay.
Post what you find.
Old 07 Jan 2019, 10:37 pm
Macgyverman1123's Avatar
Verify that the starter wires are tight, you can also take this opportunity to test that the starter is getting voltage. I would then check/replace the starter relay(s). As others suggested, I would perform a load test. Good luck, keep us posted!
2003 Pt Cruiser will crank but won't start JenK Tech & Performance Forum 11 16 Aug 2015 08:28 pm
02 non turbo no start/no crank zkamm99 General PT Cruiser Discussions 2 24 Aug 2014 02:41 pm
2003 PT Cruiser Bell Crank replacement. Srrock Canada PT Forum 6 12 Feb 2014 01:18 pm
Under drive Crank pulley for TURBO ROCKETMAN8060 Turbo Performance 3 18 Jan 2010 05:16 pm
05 Turbo Will crank but won't stay started rayscag Tech & Performance Forum 3 17 May 2009 09:33 am
