Error codes 0171 and 0172 at once
  • 1 Post By giorgio
Old 10 Apr 2019, 10:40 pm
Default Error codes 0171 and 0172 at once
Hi guys,
I have now two errors - 0171 and 0172 at once - engine running lean and rich at once. No other problems noticed. I thought, O2 sensors are faulty, but the readings seems to be ok. What could it be?
Handy_Cruiser likes this.
Old 11 Apr 2019, 12:17 pm
Handy_Cruiser's Avatar
Default Re: Error codes 0171 and 0172 at once
My first thought for both codes at once would be the throttle position sensor (TPS).
There are some diagnostics in the service manual for your PT. 2004 GT, right?. Here's a link where you can download the service manual from my Google Drive:
https://drive.google.com/file/d/0B9C...ew?usp=sharing
Old 11 Apr 2019, 07:28 pm
What year is your Pt Cruiser?
If it has the egr valve you might want to check it out.
If it does not have the egr valve it might be air leaking in from your intake through a gasket or hose. Check for vacuum leaks.
Old 11 Apr 2019, 09:19 pm
Have you tried resetting the codes?
03 Turbo AutoStick
107K
Cranny
Old 11 Apr 2019, 09:46 pm
Thanks. Yes, I have deleted the codes, but they are back
Old 11 Apr 2019, 09:58 pm
Do you have a vacuum guage?
Error codes 202, 203, 204 Dino General PT Cruiser Discussions 11 08 Jul 2017 04:11 pm
P0..NO!!NO!!NO!!! Error Codes UITA General PT Cruiser Discussions 7 03 Aug 2013 04:47 pm
Error Codes Error lilcruiser Tech & Performance Forum 2 10 May 2012 05:34 am
Help! Hard starting and hesitation - Codes 0171 & 0522 THS_Cruiser03 Tech & Performance Forum 10 08 Aug 2008 02:36 pm
ERROR CODES Kirby General PT Cruiser Discussions 4 24 Oct 2006 03:15 am
