Not sure if I ordred correct Clutch for my 07 GT
Old 15 Apr 2019, 01:01 pm
shelbyzman's Avatar
Default Not sure if I ordred correct Clutch for my 07 GT
I just ordered a clutch kit (Sachs K70340-01) and flywheel (Dmf91160) and I'm worried they might not be the right parts for my 2007 PT GT. The Sachs K70340-01 kit shows 03-05 on alot of sites but some show it is 03-07. Was there really a change in 06 that makes these not work with the second gen PT's?
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels Drop-in K&N & airbox mod Spec D tail lights Blow off plate 10.2mm plug wires
Old 15 Apr 2019, 01:49 pm
Default Re: Not sure if I ordred correct Clutch for my 07 GT
The flywheel is correct, the clutch kit is not. That clutch kit uses the older style slave cylinder used from 2003-05. Yours will be the updated part so your hydraulic line may not fit. I have never seen the newer style because my cars are all the older one so I don't know if it can be made to work or not.
Old 15 Apr 2019, 02:28 pm
shelbyzman's Avatar
Thanks for the info/heads up. I went ahead and ordered the correct slave cylinder. Do you think the clutch etc. will still work, just not the slave cylinder?
Old 15 Apr 2019, 03:41 pm
shelbyzman's Avatar
This is the correct one right? I just ordered it: https://www.amazon.com/LuK-LSC383-Cl...r=1-1-fkmrnull
Old 15 Apr 2019, 05:42 pm
Yes the rest of the clutch is the same, only the slave was different. You could have saved yourself some hassle and money by ordering it all from rock auto, but it doesn't matter in the end.
If you want to sell that incorrect slave, I may be interested in buying it.
Old 15 Apr 2019, 06:02 pm
shelbyzman's Avatar
Good to know. I will let you once my cousin gets my pt done and I get the unused parts back
Correct PN for transmitter key? bottlerocket General PT Cruiser Discussions 1 03 Jul 2015 07:20 pm
Help me choose correct key fob 03PTMOM General PT Cruiser Discussions 21 03 Jan 2015 10:56 am
What is the correct name for this hose? DevinG17 General PT Cruiser Discussions 4 16 Sep 2013 06:48 am
01 Clutch oddity-possible clutch master cylinder? opelenvy Tech & Performance Forum 6 17 Sep 2008 03:35 pm
GT 5 speed clutch noise or " clutch chatter". boosta General Turbo Discussions 3 11 Aug 2003 08:10 pm
