Changing Turbo Inlet Line as Maintenance
Old 16 Apr 2019, 03:03 pm
shelbyzman's Avatar
Default Changing Turbo Inlet Line as Maintenance
As some of you know, my cousin is changing my 07 PT GT timing belt, working on the transmission etc. I went ahead an bought a turbo inlet line for him to replace the existing one since it is only about $25. Do you think this will help the turbo last longer? There were no issues that I know of with the turbo but figure if the line is original and is starting to get clogged at all, it woudln't hurt to get a new line. Thoughts?
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels K&N style intake auto throttle body Spec D tail lights Blow off plate 10.2mm plug wires Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack "blacked out" DIY ground effects added boost gauge (in place of analog clock)
Old 16 Apr 2019, 08:30 pm
Handy_Cruiser's Avatar
Default Re: Changing Turbo Inlet Line as Maintenance
Look at the oil outlet line as well. This is where the super hot oil goes. It can clog up.
Old 17 Apr 2019, 09:08 am
Fk5 Fk5 is online now
I think changing the lines is solid maintenance advice. It is one of those things that you do whenever you have access. Usually that means after the turbo has problems and you are installing the reman. If you or your mechanic can get at them easy, change them.
2003 GT 5 speed
162,000 miles
Old 17 Apr 2019, 10:21 am
shelbyzman's Avatar
What is the part number for the outlet? All I can find is the inlet line.
Old 17 Apr 2019, 12:00 pm
For my 2007, I believe the part number for the oil drain tube is 4884278AC. You want to inspect it before buying another. The metal part may be cleanable.
Old 17 Apr 2019, 12:47 pm
shelbyzman's Avatar
Thanks!
Quick Q- turbo inlet size ? jgale Turbo Performance 1 08 Apr 2004 01:21 pm
Turbo inlet size Timmy C General Turbo Discussions 5 23 Mar 2004 08:49 am
inlet piping turbo to factory airbox amx1397 Turbo Performance 8 29 Dec 2003 12:00 am
Turbo inlet hose Brad Vandrasik General Turbo Discussions 2 19 Aug 2003 03:56 pm
Stock turbo inlet pipe wanted. PVO PT Classifieds: Want To Buy 2 01 Aug 2003 01:05 am
