Premium vs Regular
Like Tree18Likes
Old 22 May 2019, 12:43 pm
shelbyzman's Avatar
Default Premium vs Regular
I have noticed that my GT pings some if I take off fast. I use 87 octane. Strangely enough, it didn't start pinging until after I put some fuel injector cleaner in the gas. That was over a month ago and it still pings (only when under hard acceleration). I have read that mpg will go up with premium fuel which offsets the extra cost but I don't know if this is true. Just wondering?
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels K&N style intake auto throttle body Spec D tail lights Blow off plate 10.2mm plug wires Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack "blacked out" DIY ground effects added boost gauge (in place of analog clock)
Old 22 May 2019, 02:09 pm
Default Re: Premium vs Regular
If you can hear an engine "pinging" it has been doing it long before the human ear can hear it.
Many so called engine and F/I cleaners are not octane boosters and can also lead to carbon deposits.
You may simply have mileage acquired carbon deposits on your, valves and combustion chambers?
Using a higher octane fuel may not necessarily cure the problem of pinging as you are hearing.
If you are going to be running the Turbo engine aggressively you should be using high octane fuels.
Old 22 May 2019, 02:15 pm
shelbyzman's Avatar
My car has a little over 150,000 miles on it. I rarely drive it aggressively since the majority is highway (back and forth from work)
Old 22 May 2019, 02:22 pm
I try not to hotrod much at all...but sometimes I do (what is the point of the turbo if I don't get to utilize it sometimes, lol).
Hmm.... I read only what you posted..
I did forget to mention that the use of higher octane fuel will normally not increase MPG. There are exception and also needing more specific examples of what vehicle we are talking about.
Old 22 May 2019, 02:26 pm
shelbyzman's Avatar
I do get the boost going sometimes, but not often I may try the higher octane to see if it gets rid of the ping. Anything else I can try? What can happen if it continues to ping?
Old 22 May 2019, 02:29 pm
yes, run water through the intake through the large power brake hose while the engine is running controlling the engine speed manually at the throttle body to make sure the engine does not shut down.. This will FLAT KNOCK THE SHEET out of any carbon deposits.
Old 22 May 2019, 02:43 pm
Fk5 Fk5 is offline
I usually run 87 in mine. It is not recommended, but I have been doing it since about 86,000 miles. You may get better mpg with super, but I don't see any way that it will offset the cost. You'd have to get about 4 mpg more just to break even. That's not happening. We have been charting mpg since the car was new and I don't think I have found even a 1 mpg difference with a change in fuel. If you care about your car and it is pinging, you'd better use the better stuff.
2003 GT 5 speed
162,000 miles
Old 22 May 2019, 02:45 pm
shelbyzman's Avatar
What are your thoughts on Sea Foam?
Old 22 May 2019, 02:52 pm
I no longer use it when I found out all the ingredients.
If you know of a first alert responder , you can ask them to get the complete information on that product. Normally you will NOT find it posted anywhere on the internet because of the law about proprietary ingredients.
I am not saying it would harm an engine but I do categorize it under SNAKE OIL now!
Nothing really beat good old fashion WATER for cleaning an engine inside and out. So to say. LOL
Old 22 May 2019, 03:01 pm
shelbyzman's Avatar
Would using a spray bottle directly into the throttle body work?
Regular or Premium gas? StudentCruiser General PT Cruiser Discussions 10 24 Aug 2017 07:08 am
Is ok to put Regular gas if you been using Premium? ew55 General PT Cruiser Discussions 5 09 Feb 2015 07:34 pm
Premium or Regular gas for 2003 Turbo PT? ew55 General PT Cruiser Discussions 1 29 Nov 2013 07:20 pm
premium vs regular 4SPEED General Turbo Discussions 19 12 May 2011 09:04 pm
Regular Gas or Premium blackjersey Turbo Performance 20 30 Mar 2010 04:16 pm
