how do you remove the iat sensor on turbo?
Old 08 Jun 2019, 09:15 pm
shelbyzman's Avatar
Default how do you remove the iat sensor on turbo?
I am getting a p0113 code and am wanting to clean or replace my iat sensor. Does it just pull out? I don't want to break it. It is located on the hose right before the throttle bottle correct?
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels K&N style intake auto throttle body Spec D tail lights Blow off plate 10.2mm plug wires
Old 08 Jun 2019, 09:23 pm
Default Re: how do you remove the iat sensor on turbo?
You really should download or get a Factory Service Manual.
Even with my credentials I always get a FSM or at least an Haynes , Chilton or Clymer etc. on the car I own for reference.
Not all the advise on forums is the best all the time.
Suggestive reading?
Car Repair Advice Forum= at your own risk
Old 09 Jun 2019, 11:41 am
rob302's Avatar
Don't listen to him..
I recommend using the acetylene torch and cutting out a few inches around the IAT so you do not damage it. Then stick the sensor in a jar filled with vinegar and set it on the shelf like a body part in a horror movie.
Now those sensors change ohms with temperature, Honda are like
100 ohms = 248 degrees
20,000 ohms = -40 degrees
So measure yours at 60 with a multimeter, stick a resistor in it's place, and enjoy better performance... Or get the value at 248, and it should stop that annoying pinging with 87 octane
Old 09 Jun 2019, 12:25 pm
P0113 - IAT Sensor Circuit High Input Conditions:
Possible Causes:
1. IAT Sensor signal circuit shorted to VREF 5 volts
2. IAT Sensor signal circuit is open, or the ground circuit is open
3. IAT Sensor is damaged or it has failed
4. PCM has failed
Old 09 Jun 2019, 01:45 pm
shelbyzman's Avatar
Drove the car today and the code is gone.
Old 09 Jun 2019, 02:45 pm
When the code is triggered is there anything that changes? Engine idle change?
Old 09 Jun 2019, 07:43 pm
shelbyzman's Avatar
I noticed it came on the first time when I was sitting at a railroad crossing idling.
Old 10 Jun 2019, 12:36 pm
I would check the wiring and contact going to the sensor.
Old 10 Jun 2019, 02:16 pm
shelbyzman's Avatar
I did buy some electronic cleaner spray and sprayed the connector. The light still didn't come on today either.
Old 10 Jun 2019, 11:54 pm
_PTGT03's Avatar
get rid of that KN intake and you will find you're having better performance
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
ANY BODY KNOW WHAT HAS TO BE REMOVED FROM A PT TO REMOVE THE TURBO OIL LINE? Busted_PT General Turbo Discussions 1 06 Jun 2013 09:24 pm
help to remove 06 turbo a/c compressor bmacfla General Turbo Discussions 0 05 Sep 2011 12:16 pm
Crankshaft Sensor on 2007 Cruiser (remove starter?) caoreilly Tech & Performance Forum 4 04 Jan 2011 10:06 pm
Need to remove starter from 2004 Turbo Cruiser slcpunk Tech & Performance Forum 2 14 Jan 2010 03:08 pm
Remove turbo silencers = more power??? Gary04GT Turbo Performance 3 12 Apr 2004 11:32 pm
