Stuck in limp mode
Like Tree9Likes
Old 14 Jan 2020, 05:06 pm
Default Stuck in limp mode
2005 GT auto stick stuck in Limp mode
Pick this up for $460 they told me it had an electrical problem it was stuck in limp mode.
Drove it home drove fine shifted fine after I got at home restart stuck in limp mode. replace coil pack Shifting fine again after restart stuck in limp mode. Ben stuck in limp mode ever since traced All 8 Wires from the Coil pack plug to the computer all check out good. from the relay power down to the coil Pack good Found no problem with wiring did notice when I shift into auto stick 1st Gear light is not luminate But square boxes around park reverse neutral drive do Take it back out of auto stick and the square boxes go away believe when I shift into auto stick it should show me 1 for low 2 For 2nd and that Box is empty no light the code I get is P0750 low reverse only circuit can anyone help out
Old 14 Jan 2020, 05:56 pm
Default Re: Stuck in limp mode
Well I just went back out there shifted into low auto Auto stick Went into gear took it for a ride everything shifted fine restarted the car everything still working I think I have a terminal that is intermittent I know wires are good. I'll try and drive It around to see I'll react.
Old 15 Jan 2020, 06:31 am
Handy_Cruiser's Avatar
You may also have a weak front transmission pump. The symptoms are that it will work okay when cold but then periodically goes into limp home mode. Sometimes, it will just needs a restart to work okay again for a while. The best plan is to find a transmission shop that you trust and have them check it out.
rockandroller likes this.
Old 15 Jan 2020, 09:34 am
Thanks I'll keep this in mind
Handy_Cruiser likes this.
Old 17 Jan 2020, 02:25 pm
OK after checking wires at pcm for L/R pin 19 and 28 are hot with key on this is good.
12 and 14 are ground they show they are grounded before key is on and after key is on
don't think this is write I would think they would ground when called for not all the time
any thoughts
Old 17 Jan 2020, 04:39 pm
This link below might help you find what is causing your P0750 code.
https://easyautodiagnostics.com/chry...e-p0750-test-1
rob302 likes this.
Old 17 Jan 2020, 04:48 pm
If I am understanding correctly you get intermitily a square box around some of the PRNDL letters on the dash?
Old 17 Jan 2020, 05:31 pm
any thoughts
On the C4 PCM plug with the green stripe, pinouts 12 and 14 are grounded t0 the chassis of the car. So ground is constant even without the ignition being on. Here's the diagram.
You can download the 2005 PT Service Manual with wring diagrams from my Google Drive at this link.
https://drive.google.com/file/d/0B9C...ew?usp=sharing
POWERTRAIN CONTROL MODULE C4 - GREEN 38 WAY
CAV...CIRCUIT.................FUNCTION
1.......T60 18BR...............OVERDRIVE SOLENOID CONTROL
2.......T59 18PK/BK..........(2.0 and 2.4 non Turbo) UNDERDRIVE SOLENOID CONTROL
2.......T59 18PK/BK..........(2.4 Turbo) UNDERDRIVE SOLENOID CONTROL
3 - -
4 - -
5 - -
6.......T19 18WT..............2-4 SOLENOID CONTROL
7 - -
8 - -
9 - -
10.....T20 18LB...............LOW/REVERSE SOLENOID CONTROL
11 - -
12.....Z13 16BK/RD.........GROUND
13 - -
14.....Z13 16BK/RD.........GROUND
15.....T1 20LG/BK............TRS T1 SENSE
16.....T3 20VT..................TRS T3 SENSE
17 - -
18.....T15 20LG...............TRANSMISSION CONTROL RELAY CONTROL
19.....T16 16RD...............TRANSMISSION CONTROL RELAY OUTPUT
20 - -
21 - -
22.....T9 18OR/BK............OVERDRIVE PRESSURE SWITCH SENSE
23 - -
24 - -
25 - -
26 - -
27.....T41 20BK/WT.........TRS T41 SENSE
28.....T16 16RD...............TRANSMISSION CONTROL RELAY OUTPUT
29.....T50 18DG...............LOW/REVERSE PRESSURE SWITCH SENSE
30.....T47 18YL/BK...........2-4 PRESSURE SWITCH SENSE
31 - -
32.....T14 20LG/WT.........OUTPUT SPEED SENSOR SIGNAL
33.....T52 20RD/BK..........INPUT SPEED SENSOR SIGNAL
34.....T13 20DB/BK..........SPEED SENSOR GROUND
35.....T54 20VT/PK...........TRANSMISSION TEMPERATURE SENSOR SIGNAL
36 - -
37.....T42 20VT/WT..........TRS T42 SENSE
38 - -
Old 17 Jan 2020, 05:32 pm
found when in limp mode this will happen
Old 17 Jan 2020, 07:23 pm
When you are in limp mode you are getting squares around every letter of the PRNDL display on the dash?
Limp Mode....? CluelessKate Tech & Performance Forum 6 11 May 2016 11:51 am
stuck in limp mode galahad General PT Cruiser Discussions 3 13 Feb 2013 07:44 am
help..limp mode ivynthemnts758 Tech & Performance Forum 2 09 Sep 2010 08:44 am
Stuck in limp mode. Cleared some codes, but... SRT8guy General PT Cruiser Discussions 2 30 Jul 2010 07:15 am
Engine overheating, Stuck in "Limp mode" showing codes 0188,1490,&1495 Manny Tech & Performance Forum 4 08 Apr 2009 05:39 am
