Failed Hose Issues
Like Tree3Likes
  • 1 Post By Handy_Cruiser
  • 2 Post By Handy_Cruiser
Old 02 Nov 2020, 05:17 am
Default Failed Hose Issues
On both of the 05 Turbo Convertibles here, this hose has failed. It's letting air in on both and I suspect the cause of the stumbling and pathetic idle (P0172 code is set twice) on one of them.
Any idea what to exactly search for since ma mopar parts sites have no clue?
The end appears to be a cheap rubber, hence the holes and general failure. Couldn't find anything at the auto parts store, only similar rubber part I found didn't fit
Old 02 Nov 2020, 08:38 am
Handy_Cruiser's Avatar
Default Re: Failed Hose Issues
I've had the same issue. A hole in that line caused the engine in my 2005 GT is run wild. It's a good idea to replace it with rubber and then shield it from the turbo heat that comes up from directly below it.
Old 02 Nov 2020, 08:55 am
So you just 86’ed the whole plastic tube/rubber end and made it a rubber hose?
Old 02 Nov 2020, 10:25 am
I just replaced a section of the plastic hose that is subject to excessive heat from the turbo and/or experiences lots of rubbing against the firewall. Then I modified the heat wrap a little to help cover it better. I was considering using metal electric conduit as a heat shield, but the modified wrap has worked well. On my GT, I raised all the lines up above the clips and that helped as well.
Failed MOT snert Tech & Performance Forum 14 22 Dec 2017 08:41 am
Turbo Coolant hose? Replacement/Hose Size PTTuber Tech & Performance Forum 9 07 Aug 2015 05:27 pm
Failed Stg. 1 PCM..maybe dpj450 Stage Turbo Kits 10 14 Sep 2014 02:18 pm
failed mot !!! ricksatluz Europe PT Forum 9 02 Mar 2013 07:11 am
Timing belt failed, issues with valves? bama7474 Tech & Performance Forum 12 06 May 2011 06:33 am
