PT Cruiser Forum Car Videos
Car Rims
Burn Smell after pushing on gas
Old 10 Aug 2004, 01:14 am
LoboMXGT LoboMXGT is offline
Default Burn Smell after pushing on gas
Hi, just few minutes ago arriving to home i dunno why i decided to get the GT inside the garage in reverse, there is a bump/lump covered with grass on the way i'd never noticed it untill tonite, i needed to apply some serious push on the gas to bypass it but when i was getting ready to shutdown the engine, i notice a somewhat strong smell like plastic burning and some smoke comming from the hood, i did open the hood but no more smoke i did start to check where the oddor came from and it appears to emane from the area just in front of driver seat near to a big black plastic box above the battery (sorry i dunno much about car parts) what did i blow? [:I]
Old 10 Aug 2004, 02:19 am
JPMS GT JPMS GT is offline
Welcome, LoboMXGT, I could see some belt slipage or tire burn but I'm at loss as to what this could be.
Good luck
John
Inferno Red \'04 GT Autostick, Stage I, BTG exhaust, Airforce One intake, V.A.K. Candy Red upper charge pipe, BTG strut bar,Hyperground, chrome side spears and grill accents.
Old 10 Aug 2004, 11:37 pm
Jeff V Jeff V is offline
The black box behind the battery (if you're looking from the front of the car) is the airbox. The area between that and the driver's seat includes the pipe that goes from the airbox to the turbocharger.
If I was you I'd get underneath the car and look with a good flashlight, for anything you might have dragged, like a plastic milk jug stuck to your turbo up pipe - or worse, if you ruptured your exhaust or up pipe on the "lump" you had to accelerate to get by.
If everything looks good from underneath, remove the black box top and check for debris.
Did your wheels spin while you were trying to get unstuck? That could produce a small amount of "smoke" and a smell.
Old 11 Aug 2004, 08:23 am
sakigt sakigt is offline
Send a message via AIM to sakigt
Im with Jeff....sounds like your exhaust is cooking something for you
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 13 Aug 2004, 02:57 am
Thanks 2 all for your interest...
Now that i remember this is the 2nd time of that strange odder on my GT.
http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=5347
But never tough it was related cuzz that time some1 mentioned about the clutch recall on '03 MT GTs, after a month or so i felt into a
hole in the street and there were enough damage to be towed to the dealer: the 2 right side tires were literally slashed, the rims cracked and some suspension parts, so i mentioned to the technician about the incident with the clutch and the recall on it, he checked the build date and confirmed that my GT was on the range and they would remplace it, so when i picked up the GT, i asked again about the clutch and they said they remplaced it then driving to home i noticed a real diference on the clutch.
Backing to the last nite event, the smell was gone at the next morning nothing unusual on the GT perfomance, but after reading the Jeff's post, i just checked the exhaust (need to get a good flashlight for checking the motor area) it seems to be fine, the lump wasn't that big to reach it, the only noticiable thing was a black stain spot that runs along from inside to the end of the pipe but doesn't cover all just the bottom part. that's normal?
\'03 GT 5 speed Steel Blue No Mods (Yet)
Old 13 Aug 2004, 02:07 pm
Cal Cruzer Cal Cruzer is offline
El Lobo
That black strip could be a number is things. Was there any oil or anything on the bottom of the engine? Have you kept an eye on your fluid levels? If these are okay, I would suspect that you just picked up something that burned off. If it happens again I would investigate further. The infamous "intermittent problem" is the hardest to track down unfortunately.
vB code is On
Exhuast Smell hangtym3 General Turbo Discussions 4 02 Dec 2005 01:49 am
Do ignition coils burn out? crazie.eddie Tech & Performance Forum 15 29 Oct 2004 02:19 pm
New Car Smell RAK402 The Detail Shop 3 27 Aug 2004 07:18 am
Oily smell from air vent when idling Art Rigby Tech & Performance Forum 4 30 Jul 2004 11:15 am
Odd A/C smell? stirfry General PT Cruiser Discussions 10 11 May 2004 05:13 pm
  Loans | Skateboarding | MPAA | Mortgage Loans | Credit Cards
