When you folks go to the track, what tire pressure are you running up front?
Thanks, KB |
I run right around 35psi up front, but lately have been putting 45 in the rears. Here's my thinking - take it as you wish: Street radials will "crown" if you put too much air in them, allowing only the center of the tire to contact the road. Underinflate them and they will actually go a bit concave at the center, essentially just running on the outer edges. If you've ever seen those tread wear indicator photos where they show how unevenly a tire wears if under- or overinflated you know what I mean. So basically, to get the largest contact patch (and presumably best traction) out of street tires I recommend the, um, well, recommended pressure.
My rationale for higher pressures in the rears is simply for lower rolling resistance - heck, you're just towing those tires behind you, it's not like they do anything other than keep the back bumper from rubbing on the street!
chek in your door i think is 34lbs for the 4 tires
black 2004 limited edition with turbo lite stage 1 mopar bov and boost gauge. prototype power kit. k&n air filter s2 wga ebc greddy profec type 2 http://turbocruiser.monchar.com/ |
Mine says 38 psi
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
Guys, he isn't asking "what's the recommended tire pressure for a PT", he's asking "what front tire pressure are we running at the track"!
Cal, my best results have been when running the fronts at 35 - maximum contact patch seems to work best and I get consistant 14.8 runs.
25lbs to the front
Watch a dragster leap from the line. I think the slicks only have a few pounds in them,and they go convex in a nano-second. You could go to Costco and get a little nitrogen, say 15 lbs. And, I saw the guys with the Indy lights cars with what looked like motorcycle tires on to move about the pits. These would work great to hold up the back end for a quarter mile!
Inferno Red \'04 GT Autostick, Stage I, BTG exhaust, Airforce One intake, V.A.K. Candy Red upper charge pipe, BTG strut bar,Hyperground, chrome side spears and grill accents.
I think the argument is that you're NOT getting the maximum contact patch when you run the standard PSI. When you nail the gas, you get use of that contact patch for a split second, then the weight is transferred off of the front wheels, resulting in a reduced contact patch because of inertia (tires spinning causing the tire to balloon a little) and less weight on the front of your car than the 35PSI expects. Lots of FWD dragsters run their cars at reduced PSI on the fronts and increased on the rear to get better times.
\"If I had a diesel rig, with a big ol\' blade, courtesy would reign, arguments abate, cuz everyone would know, I\'d SQUASH \'EM LIKE A GRAAAAAPE!\" -- Heywood Banks, \"If I Had a Bulldozer\"
| Error Codes | skylight | Tech & Performance Forum | 7 | 28 Apr 2011 03:34 pm |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Error Code List | skylight | General Turbo Discussions | 6 | 07 Apr 2007 02:11 pm |
| Tire Accu-Pressure Safetly Cap Warning | Curruzr | General PT Cruiser Discussions | 6 | 22 Aug 2005 07:46 am |
| Tire recommendations.... a happy ending! | comPuTer | General PT Cruiser Discussions | 9 | 12 Jan 2004 03:47 am |
