Blown Gear box after Turbo Charging
Old 20 Oct 2004, 05:16 am
Default Blown Gear box after Turbo Charging
I have just killed a gear box on my 2 Litre PT cruiser Classic after it had been turbo charged.
Does anyone know of a heavy duty gear box for the PT's that can be purchased.
H E L P !
Phil [8)]
Old 20 Oct 2004, 08:10 am
I'd get a used tranny from a wrecked 03/04 GT. Others are looking into beefing those gearboxes even further but so far no one has done it that we know of. Current members here are making inquiries from high-performance tranny builders and it probably can be done...just bring lots of cash
Also on your current engine you need to keep the boost under 6-7 lbs. boost or it will go Kaboom also. They will not handle the kind of power the GT is making unless highly modified.
Deen
Old 20 Oct 2004, 11:48 am
Thanks Hyracer, I will speak with someone and see if there are any wrecks available.
Do you know if the 2Litre block will accept the tranny from an 03/04 GT?
What we basically get here is a Neon 2 litre DOHC motor.
Yes the engine did go Kboom, in fact that is now my number plate.
We are now running a Howell Automotive motor 8:6 compression with forged pistons / rods, balanced, blu printed, hi volume oil pump, Garrett ball bearing turbo with 12 lbs boost, high preasure fuel pump, port & polished head, 3" exhaust.
We get a just on 160 kw at the wheels.
From the factory they are 105 kw at the flywheel ( approx 75 to 80 kw at the wheels ).
A small improvement ! [8)]
Old 20 Oct 2004, 04:09 pm
Do you have the diesel PT's where you are? If so, those have the same transmission as the US GT's...
Old 27 Oct 2004, 05:38 am
No we don't get the Deisel or 2.4 Litre or GT Turbo models.
Can anyone tell me if the GT uses equal length drive shafts or is it a long shaft and short shaft like the 2 Litre and 2.4 Litre models.
How lucky was I? (BOV install) alceryes General Turbo Discussions 27 18 Jul 2004 11:29 am
How u drive ur Manual? Ctown General PT Cruiser Discussions 6 07 Jun 2004 08:09 pm
Turbo 5-Speed vs Auto flamedcruiser General Turbo Discussions 56 28 Mar 2004 09:52 am
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
  Internet Advertising | Find jobs | Debt Consolidation | Debt Consolidation | Myspace Layouts
