Auto Tranny Maintenance
Old 28 Oct 2004, 06:20 am
Default Auto Tranny Maintenance
At 30,000 miles I should probably replace the fluid in my auto tranny. But what should I do??[:I] I have noticed the pan gasket is a little damp with fluid so I think I should service the pan and gasketl. Pep Boys and a few others will flush all my fluids out and replace the oil for around $100 or I can have the pan removed and replace the tranny filter for around $40. My Mechanic which does not have the flush machine says replace the gasket and filter this time and flush at 60,000 to 75,000. He reasons that I need to replace the filter cause of metal shavings that sometimes are present in newer cars. Any advise??
Old 28 Oct 2004, 08:57 am
MY OPINION. Chrysler autos aren't a strong point, and fluid change prolongs their eventual death.
At 30,000 miles you should be fine, so skipping the flush, just dropping pan & filter, is more than enough. Flush next time.
Use ATF+5 - it supercedes ATF+4. If you go the Pep Boys route - watch what fluid gets used - would be more harm than good if wrong fluid used.
Old 28 Oct 2004, 04:56 pm
I really don't know the fluid line setup on the PT, but on my volvo turbo I would put it up on 4 jack stands, go under and disconnect the fluid return line from the cooler and add a clear tube to a drain pan. I would then, with the help of an assitant to move the trans to PRND21, run the car keeping fresh fluid going into the fill tube until clear came out. Then I would drop the pan and change the filter, put it all back together and was good to go. This way I was able to get all the old fluid out of the torque converter, or at least most of it.
Old 28 Oct 2004, 05:40 pm
Don't assume pan gasket is the problem. I had a persistent leak and they finally found it was the tranny oil pump gasket that needed replacing.
\'03 GT Inferno Red AutoStick - Stage 1 - Air Box Mods & K&N Filter - AMX Intake Down Pipe - Flowmaster 40 Series Exhaust - Magnacor 8.5mm Ignition Wires - Pin Stripping - Chrome Side Spears - Chrome Tail Light Covers - Chrome Fuel Door - E&G Custom Grill - Painted Rear Mud Guards - 3-D Liquid Flames - Chrome/Red Neon Washer Nozzles - Interior Neon
Help: Auto Tranny Key Release Graveone Tech & Performance Forum 10 29 Jul 2011 12:53 am
Auto Tranny question BumperBob Tech & Performance Forum 7 24 May 2005 09:13 am
Auto Tranny will shift even if in 1st gear? BumperBob Tech & Performance Forum 4 07 Apr 2005 11:07 am
GT Red Line shifts and the Auto Tranny chaase Turbo Performance 4 21 Jan 2005 10:45 pm
Changing a auto to a auto stick?? 03_PT Tech & Performance Forum 21 26 Mar 2004 08:16 pm
