Torque specifications are calculated for dry threads unless stated otherwise!
told you it was debated! Any other problems with the instructions, guys?
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
[/quote]You cannot "over torque" if you are using a properly calibrated torque wrench.[/quote]
This is not a true statement. If you use certain lubricants on the threads like PROLONG's assembly lube, you will over torque. All of the aluminum rod manufacturers warn that you take the chance of damaging or pulling the threads out of the rod because of the friction loss between the bolt and aluminum thread. Improperly lubricating the threads and eliminating the friction will allow you to go beyond the intended normal torque specs. If a test situation were set up where bolt stretch (stress) was measured based on torque, a none lubricated assembly would require higher torque to reach the desired bolt stretch while a lubricated assembly would require significantly less torque to acheive the same amount of stretch. The stress measured on the threads would show the same results. |
We are now talking about 2 different things. a TTY (torque to yield) bolt is something different than a spark plug. The TTY bolt's required clamping load is established when the bolt is in the plastic stage not the elastic stage (trying to remember the stuff I learned about TTY bolts). A spark plug is not a TTY bolt. The clamping force is to tighten the plug, granted, but it's also to compress the crush washer to form the seal.
Anti-seize is not a high performance lubricant, and I personally don't see any problem using it. |
| 3/25/05 UPDATE - DONE! - New Plugs and Wires NGK | BumperBob | Tech & Performance Forum | 14 | 31 Mar 2005 01:06 am |
| Spark plugs: newbie question | Edwin Astacio | Tech & Performance Forum | 12 | 01 Nov 2004 12:21 pm |
| spark plugs | ote69 | Turbo Performance | 24 | 12 Oct 2004 01:44 pm |
| ZEX Spark Plugs | Jerry | Tech & Performance Forum | 9 | 27 May 2004 07:32 pm |
| Spark Plugs | kidturbofan | Turbo Performance | 2 | 08 Oct 2003 10:40 pm |
