| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
I wish to change my wifes 03 Turbo Plugs. Where are they , and how much torque do you use to tighten[xx(] then down ??????????
The turbo spark plugs should be torqued to 13 ft-lbs but not less than 11 or greater than 15 ft-lbs.
2003 Almond GT AutoStick, body colored rear splash guards and hood struts, chrome gear shift, AC & vent knobs, billet steering wheel spokes and pedals, AMX1397 Turbo-Intake Pipe. |
Where are they? On the top center of the valve cover.
Your questions reflect some inexperience (please don't take offense if not), so here are some tips. Let the engine cool completely. Carefully remove the plug wires, noting where they go BEFORE removing. Blow out the plug wells so nothing falls in when removing the plugs. Using the proper socket, remove the plugs, noting any 'tightness' after the initial loosening and being careful not to strip the head if they are. Compare the plugs before installing. Look for the same length, thread length and tip shape. visually check to make sure none of the gaps are closed up. Coating the threads with anti-seize is debated, but I always do it on aluminum engines. A little goes a long way. Start the plugs by hand, using the socket (if it has the rubber inside) or an old plug boot. Finish tightening with tools, a torque wrench is a good idea. If you have some di-electric grease, use one of the old plug ends to coat the inside of the wire boots. This will keep the wires from sticking the next time you service the wires or plugs. Install the wires, making sure they are in the same place and not rubbing on anything. Check all the fluids and air filter. Service the throttle body, if it hasn't been done in a while. A battery disconnect and quick learn (with advise to your wife) would let it learn the new operating conditions. If any of this isn't something you've already read about, search for it here. Have fun getting into the karma of doing it yourself.
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
Thanks for your help regarding changing the PLUGS... [^] [?]Kennybopaloo |
If you do not know where the plugs are...I would leave it to a pro...you might mess it up...also on the Turbo Lite you have to dissonect the map sensor and the cover around the throttle cables to have full access to the plugs..
PS, 03's don't have the turbo lite option so he probably has the GT.
![]() \'04 GT 5-speed, Brand X, Air Force One Intake, Custom Flowmaster Exhaust (retired), SRT-4 exhaust no resonators, AGP Wastegate, Crusher Kit, Former Chrome Package, Mopar BOV, Custom Sub Box, Mopar Pillar Gauges, Hood Scoop, MBC, Stage 1, Mopar Stage 1 Springs, Hurst STS Future Plans: Custom Intercooler Sprayer, 2-tone Paint Job \"Hondas are like cigarettes, everyone cool smokes them\" |
Whats the point...Either Turbo you have to do the same to change the plugs...
Do not put anti-seize on the threads. I will not allow the proper torque of the plug and you can easily overtigthen it. The anti-seize can also coke on the threads overtime causing difficult removal and/or pulling the threads out of the head, especially on an aluminum head![:0]
Remember Cal both NGK and Champion say dont use anti seize!
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
| 3/25/05 UPDATE - DONE! - New Plugs and Wires NGK | BumperBob | Tech & Performance Forum | 14 | 31 Mar 2005 01:06 am |
| Spark plugs: newbie question | Edwin Astacio | Tech & Performance Forum | 12 | 01 Nov 2004 12:21 pm |
| spark plugs | ote69 | Turbo Performance | 24 | 12 Oct 2004 01:44 pm |
| ZEX Spark Plugs | Jerry | Tech & Performance Forum | 9 | 27 May 2004 07:32 pm |
| Spark Plugs | kidturbofan | Turbo Performance | 2 | 08 Oct 2003 10:40 pm |
