| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
Anyone give me a step by step for the upper motor mount install. What's the best wrench to get the larger bolt off? Not a lot of room in there. What size is that bolt? I tried to size it with a 19mm and 17mm wrench but they didn't seem to fit. Also what's the torque on all of the bolts and were you able to get a torque wrench on that large bolt? Any and all help would be good.
http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=8204
R_K_GT \'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come..... |
Thanks rice. What did you torque the block anchor bolts and the big bolt at? Were you able to get a torque wrench on the big bolt at all? I don't think I can get my torque wrench on it.....Nope, I just tried it and I can't get my torque wrench on the big (18mm) bolt.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
Tom,
After looking at the install instructions posted here there are a couple of things you should change: 1. Since you are only doing the upper mount skip the potion on the lower mount and pencil strut...you still need to support the engine by placing jack and wood block under the front edge of the bell housing, do not jack engine tranny/up. Just put enough pressure to lightly support. 2. Remove bolts attaching upper torque strut to shock tower bracket and engine mount bracket. Remove torque strut. 3. Remove Top Block Anchor. 4. Place Top Block Anchor in vice. DO NOT flip around as suggested in above install instructions as your style of mount fits into the recessed area of the Top Block Anchor. 5. Mate new torque strut to Top Block Anchor and then tighten large bolt to about 20 ft. lbs. 6. Remove assembly from vice and trial fit in car to make sure everything lines up. If it does, then reinstall in vice and final-torque strut bolt to 75-85 ft. lbs. 7. Reinstall assembly in car and tighten large shock tower attaching bolt (18 mm) to 75-85 ft. lbs. 8. Torque Top Block Anchor bolts to 43-45 ft. lbs. Deen
GT, 5-Spd, K&N filter, Stage I, AGP 3147 Big Turbo, DTEC Fuel Kit, Tial WGA, Greddy Profec EBC, DCR 55mm TB, 05 Plastic Manifold, 180 Deg. Stat, CCA FMIC, AMX hard-pipes, Water-Injection, STS shifter, Needswings 3\" DP w/dump and Borla Cat-back, BG Drop Springs, Eibach Sway Bars, Panther alloys & Eagle F1 Max-Performance Tires. Best run to date...12.93 @113.45MPH. 77 Blown Vette-runs 10\'s @ 136 MPH. |
I the drivetrain is moved while supported by the jack there are specifications for the upper mounts location. 118mm from some point to the 18mm bolt, dont have my manual handy bit its in there "torque strut adjustment"
www.cardomain.com/id/rallydrock |
Thanks everyone.
Should arrive next Monday or Tuesday.
| Anyone install Borla Dual exhaust? | crazie.eddie | General PT Cruiser Discussions | 16 | 10 Oct 2004 09:21 pm |
| Anyone install their own Mopar hitch receiver? | crazie.eddie | General PT Cruiser Discussions | 6 | 06 Oct 2004 10:15 pm |
| How to install lowering springs? | Rymanrph | Wheels, Tires, Suspension | 3 | 16 Jul 2004 01:30 pm |
| Dealer price for BOV install? | CarolinaBlue_GT | Turbo Performance | 26 | 05 Jan 2004 02:58 pm |
| Lighted Windshield Washers Install | onyxgreen | Exterior Accessories Forum | 3 | 06 Apr 2003 04:07 pm |
