Horn going dead
Old 11 Jan 2005, 09:37 am
Default Horn going dead
My hella horns were working fine untill we got the big snow, now they sound like a half dead animal. Here is how they were mounted maybe some technical people can respond. I had my novility horn mounted in my wheel well, they put a switch in my dash, so when I flip it my hella's would work, flip it again and my a-u-ga horn would work. When the snow came, the snow got packed in the wheel wells and fried the relays, along with the a-u-ga horn. I pulled out the relays, and a-u-ga horn and disconnected the relays. I plan on mounting the a-u-ga horn under the hood soon. But now my hells horn sounds like only one note is working. did the relays play a part in the install in the hella horns? I thought the relays were just for the toggle switch. confused. Gary
Old 11 Jan 2005, 10:56 am
Suggestion - under the plastic valence that the windshield wipers sit on may be a good, protected space for the horns. Some have done it, and I'm thinking of moving my aoogah horn there.
Did you replace the relays? Depending how it was set up, 1 relay or 1 set of contacts may have been for the second Hella horn, and didn't like getting all that slush.
Old 11 Jan 2005, 03:05 pm
Relays are a switch but not a toggle. The relay releases a full 12 volt charge to the accessory all at once. It is a more efficeint switch than the button you are pushing to activate the horn. Think of the old hand crank sirens. It took a while to get them up to speed. That is kind of what happens without a relay to the horn. With a relay it is like the biggest strongest guy you know steps up to the crank and gets it moving full speed instantly.
Old 11 Jan 2005, 03:30 pm
Gary,
you say in the wheel well. do you mean behind the splash sheild where the factory horns are mounted? if so you should be fine as long as the trumpet for the horns are facing down. if they are indeed dead you should be able to send to hella dealer in the US for a replacement.
Old 11 Jan 2005, 07:24 pm
Typically, a horn or light relay is used to alow a smaller wire drawing lower current to be used to run to the switch. Large power wires run from the fuse box/battery to the relay and the accessory and thinner wires run to the switch. This provides a shorter path for the higher current wire. Perhaps when you took out the old relay, the resulting wires are not large enough to carry the current for the horns and are causing a voltage drop? Just an armchair diagnosis.
Old 20 Jun 2009, 04:35 pm
Default Re: Horn going dead
Just wanted to say thanks to everyone for the information. Had a heck of a hard time finding information on where my horn is located (dumb dealer didn't give me the manual that belonged to my car. Ended up giving it to the Main dealership as an extra book). Glad I joined the forum as I may need more information in the future! Hope my horn gets fixed now!
Cheers,
Ichikisu
2006 Horn Fixed Hooligan Interior Accessories Forum 4 17 Feb 2007 08:54 pm
Retro-fitting Dead Pedal for '03 GT? CarolinaBlue_GT Exterior & Interior Styling 16 01 Apr 2005 03:34 am
Aoogah horn quicksilverdon Tech & Performance Forum 12 23 Aug 2004 05:19 pm
MOMO Pedal Set + Dead Pedal (Manual) **SOLD** Beacon Classifieds: For Sale/Trade 0 06 Jul 2004 07:28 pm
2nd horn addition for '03 GT JohnM General PT Cruiser Discussions 13 31 Jul 2003 10:50 pm
