PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
driving new GT Turbo
Old 12 Jan 2005, 06:39 pm
Lonn Lonn is offline
Default driving new GT Turbo
Any thoughts on the recommendation that new turbo engines should not be driven hard for the first 1K miles? It was suggested that I should not drive my new GT 04 Turbo over 55 for the first 1K miles?!?!?
I get the cooldown at the end of a hard drive, but is the initial breakin that delicate?
Old 12 Jan 2005, 08:24 pm
2step 2step is offline
Drive it at various RPMs and apply varying amounts of power. When pulling away from a stop, sometimes give it 50% throttle, some times 75% and occationally wide open throttle (for a few seconds, at least). It's important to mix it up a bit. Multiple trips with cool downs in between may help, too.
This would be better than a long trip at one steady speed for instance. You won't be abusing the motor at all to give 'er the gas.
Modern engines are built with tolerances close to ideal and don't need extended break-in time to "wear in " the moving parts.
Think of it as learning your car and testing it out. You need to be broken in to the car as much as the other way around. Have fun.
[8)] [8)]
Old 12 Jan 2005, 09:08 pm
rszappa1 rszappa1 is offline
Thats the way you break in any type of engine...turbo or not...any make...read the owners manual....
Old 12 Jan 2005, 10:30 pm
Gary04GT Gary04GT is offline
quote:Originally posted by Lonn
Any thoughts on the recommendation that new turbo engines should not be driven hard for the first 1K miles?...
I did not take my turbo over 4000RPM for the first 1K miles--it paid off for me by facilitating the proper seating of new parts for a "tight engine", flawless performance, and excellent gas mileage (both before and after installing STAGE 1 at 7300 miles).
Good luck, and, welcome to the forums, Lonn. [8]
Old 13 Jan 2005, 10:52 am
TurbozCS2003 TurbozCS2003 is offline
Lonn
Just drive and be smart about it. I wouldnt be flooring it all the time.
The best thing you can do, with new car is drive it about 50 miles after you pick it up and change the oil and filter. This will dump the first batch of oil which will have the most garbage from assembly. Then at 500 miles dump it again. Then at 1500 miles I would change it and switch it to a synthetic oil. I use Amsoil but Mobile 1 is good too. Then you can go 7500 mile drains with the good synthetic and know
your turbo will last.
I am finishing a 89 Shadow project car I drove for 195K miles. It has
a 2.5 Turbo engine. I used the Amsoil and their filters. I changed the oil on 20K miles drains with their bypass filter.I saved All the rod and main bearings which look brand new and there was very little engine wear. I have gone thru the motor since( bored/hone/decked, cut crank, resized rods etc) it needed a headgasket but I was impressed with it. I wouldnt use anything but a good synthetic oil, especially in a Turbo engine.
Mike
86 Daytona Turbo Z CS T-Tops 2.2 +20\'s A555 Getrag moly plate, Garrett T2 3\"SV 3\" exh GLHS Stg 2 20 PSI Boost
89 Shadow ES Turbo 2.5 T2 Garret A555 Getrag moly plate 2.5 exh
89 Spirit Turbo
90 Daytona ES Turbo 2.5 NPR Cooler, S60 50 Trim, A568 Getrag 3\" Exh +40\'s 3bar Map
90 Daytona Shelby VNT 2.2 T4 A568 Getrag Needs work
00 Durango 5.9 SLT+
02 WJ Grand Cherokee Laredo 4.7
03 PTGT Black 5 spd, Stg1, Mopar BOV
Old 13 Jan 2005, 05:08 pm
GR8FLPT GR8FLPT is offline
Sweet. I always liked those little turbo shadows. Fun little sleeper... [8)]
04 GT 5 spd, S1, Mopar Sways, Eibach springs, Airbox mod, K&N drop-in filter, AGP & AMX hard pipes, debadged, PTeazer grill, bumperette, rollpan, Cowl Induction hood & other assorted painted parts!!!
Old 13 Jan 2005, 05:10 pm
Thanks to all who responded - good info - looks like I have a bit more learnin and things to do, but love the car, so it's worth it.
Old 13 Jan 2005, 05:17 pm
If you like shadows here is a nice clean looking Spirit RT for 3000$
in west virginia for sale. These things are rockets if modded a tad.
http://www.megahosted.com/gallery/SpiritRT
89 Spirit Turbo
00 Durango 5.9 SLT+
vB code is On
Turbo PT and Winter Driving madcruiser Turbo Wheels/Suspension/Handling 3 04 Apr 2006 09:07 am
Putting an srt-4 turbo or PT turbo, onto a N/A PT Carchrism5 Tech & Performance Forum 2 14 Dec 2005 12:27 am
How lucky was I? (BOV install) alceryes General Turbo Discussions 27 18 Jul 2004 11:29 am
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
  Credit Cards | Mortgages | Pink Ranger | Flights | Myspace Images
