| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
Whatever the quality you choose the 3k mile change will probably save you from destroying your 2.4. (It,s not just the particulate matter that brings on wear in an engine.) |
Thought that having one of the studies might help with this issue!
Check it out! http://www.minimopar.net/oilfilterstudy.html |
I've got an issue with an intermittent oil light. Several times a week (maybe one in ten starts), the light won't go out. I just have to shut the engine off briefly and restart it for the problem to go away. This has happened with new and old filters.
I was told there are two possible causes for this. First is a bad oil sender. Second, a poor oil filter. The story I was given (by a dealer) is that a bad oil filter may drain when the engine is off. When the engine starts, air gets trapped in it and causes the sender to detect a problem. Quickly shutting the engine off allows the air to escape and then the filter functions normally. Hmmm, it has an air of plausibility but it also could be a ploy to get me to come to the dealership for changes. What do you think?
\'03 GT - No mods \'05 Convertible Touring Ed. - No mods |
Sawdust123, I had to get my oil sender unit changed out at about 10,000 miles as the oil light would not go out. It started to behave just like yours is now though! Just a bad sending unit and all is well now for over 20,000 miles. Warranty item for me! PN 4608303AB
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
Canton/Mecca filters are the best but at $80 for the housing and between $7-$10 for the replaceable element ill stick with the disposable for now.
www.cardomain.com/id/rallydrock |
Purolator pure 1 and Mobil 1 are both great filters. Changing oil (especially synthetic) at 3000 miles is a huge waste of money. Even on a turbo motor you can easily go 5000 miles. If you don't believe me, send a sample of your used oil to a lab such as this one: http://www.oillab.com/ Also, our turbos are WATER COOLED, and the motor has an OIL COOLER. There's virtually no chance of oil coking in the turbo or oil breaking down from high temps.
\'03 GT 5-speed. Stage 1 ECU, Konis, Stage 1 springs, Kumhos |
Black 2004 PT Cruiser GT with chrome accent package, chrome door spears, billet gauge eyebrows, chrome beltline, Autotechnica tail light covers painted body color, TYC by Elegente backup lights and GPS Navigation. Silver dragons on sides and hood. Stage 1! Spark plugs gapped to .040, and installed a set of Crane Firewires. BTG cold air intake, AMX1397\'s Turbo Up Charge Pipe, Boomba Racing BOV, Hallman Pro PX manual boost controller and Mean Green\'s Hyperground Solution. http://mysite.verizon.net/vze247vu http://www.ptcruiserworld.com/Junior
I disagree. The color of the oil has nothing to do with whether or not it needs to be changed. For example, in heavy diesel engines the oil looks like TAR almost immediately after it's changed, and then the oil is used for 25,000 miles or more. On the other hand, a lot of newer cars have clear, clean looking oil at 5000 miles, but an oil change may be past due. The oil's appearance means nothing. The things to be concerned about are: 1) moisture accumulation, caused by short trips and not letting the motor warm up. This will turn the oil to sludge in short order. Generally not a problem if you get on the highway for a few miles once in a while. 2) Overheating of the oil, which will cause it to break down. This isn't an issue for our cars because of the oil cooler. 3) Loss of additive package (detergents, mostly). This is normal for any oil and will occur over time, regardless of what oil and filter you use. It's kind of like when you wash dishes - you need to change the water once in a while because the soap gets "used up".
DCX recommends 5000 miles between oil changes (with standard oil), and they are being very CONSERVATIVE because they have to warranty the motor. Volkswagon and others also recommend 5000 mile intervals for their turbo motors. 5000 is not unusual. They wouldn't recommend doing something that would damage the motor. 5000 is very SAFE for normal use. Oil companies and mechanics LOVE to preach about 3000 mile oil changes, so they can make more money. I'm going to send a sample of my 5000 mile oil to a lab in a few weeks, and I'll let you all know what I find out.
| Cabin air filter | AlmondTurbo | General PT Cruiser Discussions | 14 | 04 Apr 2008 06:46 pm |
| Whats up with factory oil filter | yotehunter | General PT Cruiser Discussions | 10 | 09 May 2005 08:28 am |
| Watch out K&N! | azptcruiser | Non-PT Discussions | 3 | 01 Apr 2004 11:55 am |
| K&N filter oil on BTG filter? | Punch | Turbo Performance | 1 | 15 Oct 2003 11:55 pm |
| Oil Filter Removal | jramosGT | Turbo Performance | 12 | 03 May 2003 06:44 pm |
