PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
TRANS FLUID
Old 25 Jan 2005, 03:18 pm
DARK270 DARK270 is offline
Default TRANS FLUID
anybody out there recomend changing trans fluid?? if so to what?
would it help performance?
Old 25 Jan 2005, 03:42 pm
2step 2step is offline
For manuals, use a good grade of synthetic.
For auto, change it even more often than recomended and think about adding a larger capacity cooler. There are additives available but I don't know much about them. [:I]
Old 25 Jan 2005, 04:11 pm
nozzano22 nozzano22 is offline
From all I have heard, (try a search on the topic) you should really use the Mopar fluid. I am a fan of AmsOil, but Apparently Mopar has special ingredients to keep the transmission working properly. From what I read, they have had failures in the early units, and the additives are essential to longevity.
Mike
Old 25 Jan 2005, 05:41 pm
Should do a flush - just draining leaves some "old" behind. ATF+4 is required, but ATF+5 supercedes ATF + 4.
I had mine flushed at 50,000 miles and filled with ATF+5.
Old 26 Jan 2005, 01:03 am
SteelBlueGT SteelBlueGT is offline
I think every 30,000 miles should be changed and a new filter installed. Flushing is better than changing but changing this often should be fine too. When they flush do they change the filter? Valvoline makes the ATF for Mopar. They have it available to the aftermarket. It's part number VAL324 Valvoline MaxLife ATF. Retail cost should be around $2.50 per quart. It is rated at ATF 4.
And, I thought we already had a tranny cooler built into our cars, right or wrong?
Old 26 Jan 2005, 04:24 am
ok, cool...now one more question 'changing' it or 'flushing' is that something i can do?? or should i have someone else do it?? i have upgraded to stage 1 with BOV(wasn't too bad) and injectors ANd dual exhaust and spark plugs..so i am handy......what do you think??
also given all the upgrades i have done i'm looking for HP..i heard about changing the underdrive pulley..anyone else done this?? maybe there is something else i cna do??? thx for the help!!!![8)]
Old 26 Jan 2005, 09:27 am
Filter should always be changed. Draining is just dumping the pan, flushing changes the fluid in the torque converter also.
Yes, the PT has a transmission cooler.
Old 29 Jan 2005, 12:00 pm
MYREDPT MYREDPT is offline
OK, I am REALLY going to show my age here. Back in the 60's, we ran a bunch of Mopar Torqeflite Transmissions and they all had a little drain plug to drain the torque converter. I wonder how they "flush" out the torque converter now-a-days? Do they just pump fluid through the trans cooling lines? Does that really flush out the torque converter? [:I]
Old 29 Jan 2005, 03:50 pm
1ptturbo 1ptturbo is offline
I would recommend only using the MoPar ATF+4 and ATF+5 if Chrysler recommends it for your particular transmission. I would not use the valvoline Max Life, it is a best guess to the ATF+4 and no where have I seen where "Chrysler" recommends this as an alternative. I would recommend replacing the fluid and filter every 15,000 with no need to "flush" the transmission. If you have exceeded the 15,000 then I would recommend flushing the converter and then every 15,000 after. If you tow, climb a lot of hills or lots of stop and go traffic, then I would recommend flushing the torque converter.
I see a lot of dead transmissions @ 60k with the so called Lifetime fluid and the fluid is oxidated @ 30k, it is a tough sell to get the owner to change it @ 30k when the fluid is 30.00 litre but a 6k + tranny @ 60k can change their mind. So, pay a little extra for the Mopar fluid every 15K. Also, I would recommend you only use a MoPar filter!!!
Old 30 Jan 2005, 12:12 pm
steve smith steve smith is offline
you meen if i have 14300 i got to do my trans fluid and filter change soon wow[:0]seem very fast
black 2004 limited edition with turbo lite stage 1 mopar bov and boost gauge. prototype power kit. k&n air filter s2 wga ebc greddy profec type 2 http://turbocruiser.monchar.com/
vB code is On
TRANS FLUID TYPE? ptTurbo528 Tech & Performance Forum 9 03 Jan 2006 03:05 pm
I think my tranny's about to go! TaylorMade Tech & Performance Forum 25 01 Apr 2005 12:46 pm
Fluid coming out of exhaust... crazie.eddie General PT Cruiser Discussions 10 11 Nov 2004 04:21 pm
Shocks/Struts and Trans Fluid 1lowufo Tech & Performance Forum 3 04 Nov 2004 02:15 pm
ATF+4 auto trans fluid finally available MX-5 Tech & Performance Forum 3 04 Sep 2003 01:20 am
  Car Finance | Apply for a Credit Card | Credit Cards | Mouth Cancer | Bad Credit Loans
