PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Manual 3rd Gear
Old 09 Feb 2005, 02:26 am
don668 don668 is offline
Default Manual 3rd Gear
Has anyone besides me find shifting up into 3rd a bit rougher than the other gears? Mine seems to bump a few times before going in. (tried double clutching, waiting a moment, no difference) Its like its not quite synchronized. Mechanics have noticed it and changed the linkage, but no difference. Unfortunately it can be a bit sporadic so on road tests lately it shifts great.
(I was a driver trainer for Laidlaw for 7 years so I'm fairly sure its not my driving)
Don
Old 09 Feb 2005, 03:54 am
Mean Green Mean Green is offline
You are not alone. I got the Hurst sts and it helped alot. Also, don't shift into third with your hand down on top of the shifter. Shift with your hand upside down and you will find you have more control.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 09 Feb 2005, 07:52 am
hyracer hyracer is offline
Our manual trannys are not the smoothest shifting trannys I have ever owned. Mine was "rachety" when I bought it and is still that way after adding Booger bushings and the STS Mopar shifter. The short throw is great but it's not smoooooooooooth.
You have to remember the HD 5-spd was originaly used behind a diesel engine (European model PT's. It was never designed to be slipped into a "hot-rod".
Deen
Old 09 Feb 2005, 09:55 am
TurbozCS2003 TurbozCS2003 is offline
Changing the tranny fluid doesnt hurt either.
I dumped mine and replaced with Amsoil synthetic ATF, shifts pretty good. Also changed the two bushings under the air box on the bell crank for the linkage with the urethane booger bushings.
Note it is probably a good idea to dump the ATF once a year in these things. At least there are two pipe plugs to do the service but is a kind of a pain, needed to snake my pump(get a suction pump at auto store to refill) hose around stuff to get to the top filler plug.
Personally I find it pretty decent gear box to shift, but I am use to the getrag gear sets in my other cars. Price you pay for having a gear set which can handle gobs of tourque.
Mike
86 Daytona Turbo Z CS T-Tops 2.2 +20\'s A555 Getrag moly plate, Garrett T2 3\"SV 3\" exh GLHS Stg 2 20 PSI Boost
89 Shadow ES Turbo 2.5 T2 Garret A555 Getrag moly plate 2.5 exh
89 Spirit Turbo
90 Daytona ES Turbo 2.5 NPR Cooler, S60 50 Trim, A568 Getrag 3\" Exh +40\'s 3bar Map
90 Daytona Shelby VNT 2.2 T4 A568 Getrag Needs work
00 Durango 5.9 SLT+
02 WJ Grand Cherokee Laredo 4.7
03 PTGT Black 5 spd, Stg1, Mopar BOV
Old 17 Feb 2005, 12:15 am
PTGT_Boy PTGT_Boy is offline
A hurst short shifter (Mopar) did improve the 2-3 and 4-5 shifting of my 5-speed.
vB code is On
Service manual Shini Quiet General PT Cruiser Discussions 3 18 Oct 2005 02:16 am
Best manual for an '03 GT? sawdust123 General Turbo Discussions 4 19 Jan 2005 11:46 pm
p0733 Gear 3 Incorrect ratio p0733 Gear 3 Incorr RobGT General Turbo Discussions 12 04 Nov 2004 02:02 pm
How u drive ur Manual? Ctown General PT Cruiser Discussions 6 07 Jun 2004 08:09 pm
Haynes Manual CREWZIN Tech & Performance Forum 1 03 Mar 2003 05:25 pm
  Comcast | Personal Loans | The eBay Song | Online Loans | Image Hosting
