PT Cruiser Forum Car Videos
Car Rims
engine light on
  #11 (permalink)
Old 24 Feb 2005, 08:03 pm
Mr.2U Mr.2U is offline
the 3 turns thing with the ignition key
does not work on an 04'
stopped by the dealer and he was nice enough to bring out his
code reader and we did it right in the driveway, turned out to
be a alarm code for the power steering pump,he said it happens
somtimes on manual cars when you kill the car by being poor
on the clutch at the same time you are turning sharp.
the sensor knows the pump is working hard and there is not
enough rpms for the pump to work well, hence you get a code
he cleared it and i was on my way in 10 minutes
thanks for the ideas
  #12 (permalink)
Old 25 Feb 2005, 10:30 am
So it was driver error?
I think we all learned something on this one - I didn't know PS pump would throw a code.
  #13 (permalink)
Old 25 Feb 2005, 11:40 am
SuGamer SuGamer is offline
Sorry Mr.2U, but the ignition key trick does work on '04's. I have a 2004 PT GT, and check all the time because there are some codes that will not set off the CEL. You have to start in the off position and go, on, off, on, off,on. On the 3rd time, leave the key in the on position and the car will either show "donE", or give you codes then show "donE" where the mileage is normally shown.
  #14 (permalink)
Old 25 Feb 2005, 08:35 pm
MX-5 MX-5 is offline
There is a power steering pressure switch that tells the PCM to increase the engine rpm during increased load on the pump. This is easy to see. With the engine at idle in gear, turn the wheel sharply. You will see the rpm increase just over 100 rpm to compensate.
vB code is On
Check Engine Light CHROMEDCRUISER General PT Cruiser Discussions 11 16 Jul 2008 11:46 pm
Faulty Check engine light? Mel K General Turbo Discussions 5 23 Mar 2007 10:06 am
Check engine oil light question AaronR General PT Cruiser Discussions 5 28 Aug 2004 03:18 am
Clearing check engine light Blade Tech & Performance Forum 10 27 Mar 2004 01:48 am
"Check Engine" idiot light on AGAIN tezz General Turbo Discussions 11 10 Jul 2003 04:55 pm
  Educacion para la vida | Mortgage | Homeowner Loans | Loans | Loan
