PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Oil question
Old 17 Mar 2005, 08:12 am
Default Oil question
Okay. Heard from dealer - my '05 turbo on order has been built, is being shipped - woohoo!
Question - I know the turbo has a bigger oil filter - what is an oil change? 5 1/2 quarts? I like how my exisiting PT takes exactly 5 quarts and WalMart sells Mobil1 in the 5-quart jugs - perfect. Oh well, I guess a jug and a quart.
Soon as I get it, Mobil1 and K&N filter.
Old 17 Mar 2005, 12:09 pm
SuGamer SuGamer is offline
Don, I have personally changed my oil twice and both times I only needed 5 quarts, even with a K&N filter. [?]
Old 17 Mar 2005, 01:01 pm
Mike Radowski Mike Radowski is offline
Every time my dealer changes oil in my wife's GT we give him 5 quarts of Mobil One and we check the dipstick after we get it back and it shows full. Go figure.
Mike
Old 17 Mar 2005, 02:35 pm
So do we figure the oilpan is just that much smaller for the turbo - because the filter IS bigger?? [:I]
Anyway, 5 qts it is - good news.
Hey, maybe they just recalibrated the dipstick?
Old 17 Mar 2005, 05:13 pm
Cal Cruzer Cal Cruzer is offline
The filter is not that huge and it is filled with filtering media that displaced most of the space. You can't just look at a larger filter and think that it will hold that much more oil.
Old 17 Mar 2005, 05:28 pm
JPMS GT JPMS GT is offline
Welcome to the TURBO CLUB, Don! Did you order the SI with it?
You may want to check other posts on changing in the Mobil 1. I think there was a reason some guys felt waiting to the first oil change was the way to go. Don't forget the pictures when you pick it up. [^]
Inferno Red \'04 GT Autostick, Stage I, BTG exhaust, Airforce One intake, V.A.K. Candy Red upper charge pipe, BTG strut bar,Hyperground, chrome side spears and grill accents.
Old 17 Mar 2005, 09:29 pm
rszappa1 rszappa1 is offline
If you look at your owners manual when you get thecar you will see that it says 5 quarts...all of the turbos use 5 quarts with a filter.
Old 18 Mar 2005, 12:54 am
Jeff V Jeff V is offline
I've changed my oil six times now, each time with the Mobil One 5-qt jug (did you notice Walmart recently upped the price from $18.88 to $19.97? - who do they think they are - Target?) and it was a perfect fill every time.
Old 18 Mar 2005, 02:12 am
Topless in Cali Topless in Cali is offline
Don,
Yes, its 5 quarts, and no, do not change it immediately or put in a filter right away! Do it after the break in period. All vehicles new have a layer of special lube on the innternals that needs to burn off first with the original oil and putting that high flow filter will just add super fine dust to the mix. I go about 800-1000 miles break in, after that do the oil and filter. If you put the new oil in right away, you will be mixing that burn off and extra particles into good synthetic during that crucial time in the engine's life, basiclly wasting the new oil. just drive mellow for the breakin period, Have some patience....
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
Old 18 Mar 2005, 02:26 pm
quote:Originally posted by Topless in Cali
Don,
??? Assembly lube is used to reduce friction in the first time start of the engine when there is no oil in a lot of the engine. Even then they will have pressurized the engine once before start up. Assembly lube is basically gone after the first start. There is no "burn off" and certainly no harm to engine oil. Manufacturers don't even use a "break in" oil any more as far as I know. They simply call for a low "first number" in the vicosity rating of the engine oil. They used to call for an early oil change to dump the breakin oil but no more. IMHO it is a good idea though to still do an early oil change and inspect the oil just to make sure there is nothing bad going on inside.
vB code is On
Question For Gary BenWaB3 The Detail Shop 1 29 Sep 2005 09:57 pm
Mirror was broken, Question? stirfry General PT Cruiser Discussions 6 14 Sep 2005 11:30 pm
Rear Shelf Question technobear Interior Accessories Forum 23 13 Aug 2005 12:23 pm
Question: Wheels and PT Wheel Wells PTGT_Boy Turbo Wheels/Suspension/Handling 42 13 Sep 2004 11:46 pm
question about head unit upgrade Avus Sound and Security Forum 1 08 Jun 2004 06:32 pm
  Best Credit Cards | Video Codes | Just Holden Commodores | Modded Xbox | Car Insurance
