mostly city with a 25Km of highway commute in between. Try to play that point with the wife when I bought the PT. Her answer was "you got the slapstick what more do you need." Now, she slowly coming around when her Volvo tranny died at the young age of 120,000Km. Anyway, how reliable is the Autostick compare to the regular automatic?
My advice would be to change the fluid yourself every 30K miles with a new filter. Use the ATF+4. I have a 5 spd manual in my PTGT but have two autos, 545RFE in my Grand Cherokee and 46RE in my Durango. In both I droped the pans early, cleaned the magnets, changed the filter( 2 in the 545RFE), installed B&M drain plugs, refilled 6 qts or so for normal pan drop service, disconnected return line from coolers, dumped and added 1 qt at a time( start and put in drive for 30seconds or so with foot on brake to pump out 1 qt into a bucket) until I used about 14 qts to ensure all fluid was replaced. Then reconnected return line. I used AMSoil Univesal ATF, runs great.
86 Daytona Turbo Z CS T-Tops 2.2 +20\'s A555 Getrag moly plate, Garrett T2 3\"SV 3\" exh GLHS Stg 2 20 PSI Boost 89 Shadow ES Turbo 2.5 T2 Garret A555 Getrag moly plate 2.5 exh 89 Spirit Turbo 90 Daytona ES Turbo 2.5 NPR Cooler, S60 50 Trim, A568 Getrag 3\" Exh +40\'s 3bar Map 90 Daytona Shelby VNT 2.2 T4 A568 Getrag Needs work 00 Durango 5.9 SLT+ 02 WJ Grand Cherokee Laredo 4.7 03 PTGT Black 5 spd, Stg1, Mopar BOV |
I know nothing about the longevity of the PT's stickshift since I have an automatic slap shifter, but I know that the secret of keeping an automatic from breaking is keep the heat down, fluid clean and cool, and dont abuse it by WOT[8)] shifts.
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
Mine just went at 25k. Not sure why. I think there was something wrong with it, cause I don't drive that bad and I don't race.
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
I ordered the clutch from tommy. Also order a flywheel in case the original is heat baked.
I don't want to go thru the headache of trying to get them to resurface it. I also need my car back. I got the clutch for 275 vs 335 and the flywheel for I think 210 vs the 381 they wanted. Labor kills, their going rate here is about 71/hr. I'm going to ask for the original clutch from them so I can take a closer look. I have a feeling that when the dealership I bought the car from installed it when they did the recall, that something was awray.
Mr PTGT Redman
You mention a recall: "I have a feeling that when the dealership I bought the car from installed it when they did the recall, that something was awray." Was the original replaced under a recall and the one which just failed was the repalcement the dealer installed?? What was the recall about and is there a build date/cutoff? My 03 was a late build in june 2003. Mike
| Review- New performance clutch install for the GT | FastNJPT | Turbo Performance | 2 | 26 Sep 2006 10:13 am |
| New Clutch went bad after 2 weeks??? | Ctown | Tech & Performance Forum | 3 | 12 Mar 2005 04:18 pm |
| Clutch Replacement | WaterBoy | Tech & Performance Forum | 3 | 08 Nov 2004 12:05 am |
| Clutch Replacement | CruiserDan | Tech & Performance Forum | 4 | 08 May 2004 01:14 am |
| Clutch Problems? | ptgtcb | General Turbo Discussions | 2 | 24 Apr 2004 12:11 am |
