P0440 fault resets and comes backin PT cruiser2003
Old 02 May 2005, 11:17 pm
Default P0440 fault resets and comes backin PT cruiser2003
one month back a Check engine light came on and code was P0441 . took to the dealear , He replaced the purge valve. the fault reappeared after two days and this time fault was P0440. took to the delear he found that LDP is bad and needs replacement.He did not have part , so part was ordered and not replaced.after three days check engine light disappeared, after two weeks today it apperaed again and code is P0440.
I also observed that this code apeared just after restarting the vehicle after five minutes of 30-35 miles drive with air conditioner. Do this can have any relation ship.
What can be the cause?
Old 09 Sep 2009, 06:09 pm
Default Re: P0440 fault resets and comes backin PT cruiser2003
Right now I'm having the same problem which has caused me to not be able to pass inspection. I found this though
WikiAnswers - What does the code p0440 mean for 2003 pt cruiser
Old 09 Sep 2009, 06:17 pm
You need the NVLD pump. The switch inside it is known to be faulty. And intermittant. That's why it can be hard to catch the first time. And why the light will come and go. Essentially the p0440 and p0441 is a request to replace the NVLD. Take it to the dealer and get'er done!
Old 07 Nov 2011, 06:52 pm
JaviPTGT's Avatar
Send a message via Yahoo to JaviPTGT
I got the same thing right now any pics on what this part looks like or how to change it
Old 08 Nov 2011, 07:49 pm
mjb457's Avatar
Me2 --happens about every 1000k miles or so,,, I just disconnect negaitve on battery which turns off lite---and good to go--I wouldnt mind knowing what to change if not hard or costly--doesnt have any effect on car drivability as far as I know?/ thanks MJB
