Battery Corrosion
Old 10 May 2005, 03:03 am
Default Battery Corrosion
Just checking my battery cause of the error codes I got and I found a lot of white battery corrosion on the positive terminal. Never noticed this but since I have put on my lexan battery cover I have been a naughty boy and have not looked for about 6 mo!! Is this normal or a reminder my factory battery is almost 3 years old??[xx(]
Old 10 May 2005, 08:49 am
Normal for a battery getting on in age. Those felt discs that go on the posts help, as does a coating of vaseline on outside.
Old 10 May 2005, 02:07 pm
rinse with water and baking soda to neutralize the acid.
i use a thin layer of grease and those little caps don spoke of and my battery stays clean now. its still the factory one, going strong after almost 5 years! (jinxed now [xx(])
Old 10 May 2005, 02:13 pm
Some is normal, but if it's heavy, check the battery and charging system. When stuff gets tired, the deposits get worse. Most common problem is when the battery gets weak. The charging system works harder to compensate, and boils the electrolite more.
Old 10 May 2005, 02:35 pm
You could also have developed a leak aroung the post. If this persists I would replace the battery ASAP. The gas that leaks from the battery is highly explosive and very corrosive. My son had one explode a few years ago in his 67 Mustang that he had at the time. What a mess.
Old 10 May 2005, 07:30 pm
Did that last night and toped it off with
Wd40 spray and wiped excess off. Will check again next week and see how we are doing. Will put those lilttle caps on when I replace the battery!
Old 17 May 2005, 04:27 pm
think I got an acid leak somehow cause 1 week after I cleaned it up real good it has a mound of white crud as big as ever on the positive terminal. Guess I need to look into Optima battery next.
Old 17 May 2005, 07:03 pm
Yup, change the battery ASAP, those gasses are bad.
Old 18 May 2005, 10:26 pm
Send a message via AIM to PT4U2C
Still have original battery after 5 years(01 TE born March 2000). Had same issue as described until I cleaned posts, installed felt pads, and a dab of vaseline. Fine since. Seems to be characteristic of the PT. My '03 Dream has been acid free -so far.
PT4U2C
01 TE Shale Green 17\" Casinos w/Kuhmo 712\'s Bassani,Stull,Full Xenon detailed engine,K&N blane struts: 03 Dream HOT Lot\'s of chrome, Mopar duals, T&T grille,Air raid Blane struts,
autotecnica head/tail light trim, street-rod, turbo badging,auto meter gauges w/pro pod full LED\'s
Old 19 May 2005, 06:47 pm
PT4U2C
If he is seeing that much buildup in one week he has a serious problem with the battery. It can corrode the battery connection off in no time and then he will be replacing the battery cable too.
PT Crusier battery dies after 5 days of no use. PT OWNER General Turbo Discussions 22 28 Jan 2009 11:51 am
Optima Battery Gear_Head General Turbo Discussions 11 09 Nov 2007 02:47 pm
Tried a battery search???? gonzomania General PT Cruiser Discussions 7 22 Feb 2007 12:31 pm
Fixing Bead Corrosion ? durgin Wheels, Tires, Suspension 5 17 Nov 2005 04:41 pm
BATTERY SOURCE NEEDED clevelandmike General PT Cruiser Discussions 3 06 Oct 2004 09:54 am
  Properties in Egypt | Find jobs | Free Movies | Loans | Find jobs
