PT Cruiser Forum Car Videos
Custom Wheels
Electric Oil Pressure Unit
Old 10 May 2005, 09:39 pm
Paw Paw is offline
Location: Upper Sunshine Coast, British Colimbia, Canada.
Default Electric Oil Pressure Unit
I'm interested in putting in a electric oil pressure sending unit. Anyone on the forum know the NPT fitting or thread size that would fit the oil plug opennng on the block.
Thanks
Old 11 May 2005, 08:18 am
Dunno, but have a suggestion. Why not put in a "T" fitting and keep the idiot light and add the gauge. [:I]
Old 11 May 2005, 11:02 pm
Paw Paw is offline
thought about that, I think there might be too much flex with the extension on the tee for both the oem sender and the electric sending unit. The oil plug on the block by the air box is still the best place for the aftermarket sender.
Thanks for the idea
Paw
Old 12 May 2005, 09:15 pm
CJJ CJJ is offline
Send a message via AIM to CJJ
Take a look down by the oil filter. There is a plug in the pan (actually 3) I have been told the one on the end facing to the rear is an excellent place to put the oil pressure sending unit. The head position evidently gives lower readings than the actual oil pressure. CJJ
Old 12 May 2005, 09:30 pm
Paw Paw is offline
thanks for the info, I'll take a look for it this weekend. If it works out, I'll try putting one there at the next oil change.
Paw
Old 15 May 2005, 04:12 pm
Alini Alini is offline
There is a plug at the driver side of the head. Thats where I put mine and the sending unit fit perfectly with no adapter needed.
Chris and Alison Nolan
Old 15 May 2005, 04:48 pm
Paw Paw is offline
Is your electric or mechanical? i have a electic sending unit that comes with a 1/8" NPT ends. When I take the plug out should I expect a steady run of engine oil coming out of it?
Thanks
Paw
vB code is On
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
Oil pressure sending unit littleblueGT Turbo Performance 3 27 Oct 2004 02:44 pm
oil pressure gauge GTPT Turbo Performance 6 30 Sep 2003 06:03 pm
  Bad Credit Mortgages | Remortgages | Loans | Advertising | Credit Card
