Go Back   PT Cruiser Forum > Regional Forums > Gulf PT Forum
Radiator problems
View Poll Results: What to do about radiator
Mechanics 0 0%
Do it by seld 1 100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Old 03 Dec 2011, 11:24 am
Default Radiator problems
Hi my name is canon ive been having radiator problems the flow tank has not moved any I have had to add fluid were the pressure cap is every month for last three months it over heats quick I bought a dlush it dont understand how to use it and no fluid is leeking from under the car nor is there grey smoke out of tailpipe so why is it evaporating so fast what should I do.?
Old 03 Dec 2011, 12:30 pm
Default Re: Radiator problems
That's one of the longest sentences I've ever read! Guess they don't teach punctuation where you come from.
You said you bought a "dlush". What the heck is that?
Why do you have a poll on top of your post that has nothing to do with your problem? The radiator is probably fine.
IF I understand what your trying to say; you either have a small leak that you can't find or you have tiny head gasket leak which you wouldn't see out the tailpipe because the coolant is being burned in the combustion chamber.
Take it to a mechanic and have them do a pressure test, compression test and a leak down test to find out where the water is going.
Finally, do you own a PT Cruiser? What year, what mileage and what maintenance has been done to it?
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 04 Dec 2011, 03:09 am
UptownSport's Avatar
His fans maybe not working?
It's just boiling over like mad?
Turn your heater ALL the way up under 20MPH until you get it fixed!
Radiator Help Tyrusaurus Tech & Performance Forum 11 24 Aug 2011 02:23 pm
Radiator Fan Problems (again) renshaw86 Tech & Performance Forum 1 12 Aug 2011 01:30 pm
Can I take out the A/C radiator? fduffy28 Tech & Performance Forum 4 30 Mar 2011 10:49 am
PLEASE HELP! with my Radiator fan NIL8r General PT Cruiser Discussions 10 02 Apr 2010 06:58 am
radiator sandylolee General Turbo Discussions 0 04 Jun 2009 12:59 pm
