Go Back   PT Cruiser Forum > Regional Forums > Gulf PT Forum
Water draining into passenger floorboard
Like Tree8Likes
Old 07 Jun 2014, 12:44 pm
Default Water draining into passenger floorboard
I noticed just the other day that I water pouring into my passenger side floorboard from underneath the dashboard. There's a black cylindrical shaped thing with two wires (black and red) going around it and the water is coming from a small hole on the bottom, just to the side of the middle on the bottom. A little bit of water is leaking out from above this cylindrical thing, but the majority of it is coming through that hole. I've read that it could be a clogged a/c drainage hose, but I could not find anything resembling a drainage hose under my car. I checked the cabin air filter, thinking that it was clogged, but found that my car came without one. I put a brand new cabin air filter in this morning. In the 10 miles I drove, the bucket I put underneath the leak collected about 3 cups of water. I've attached a picture of the area that is leaking. You can see thick condensation on the far left in the background.
Can someone please help me figure out what this is and why it is leaking water? (yes, it is water. A bit dirty, but I'm positive it's water.) I drive a 2007 PT Cruiser, Pacific Coast Hwy Edition with just over 57000 miles on it. I bought it with less than 200 on it brand-new from the dealership in 2007.
Old 07 Jun 2014, 12:48 pm
boonie2's Avatar
Default Re: Water draining into passenger floorboard
Leaking Water NOT Antifreeze?
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 07 Jun 2014, 12:50 pm
Yes, I am positive that it is water. It's clear with some dirt in it and does not have a strong smell.
Old 07 Jun 2014, 01:19 pm
Check your AC Drain to make sure it is not pluged. It hangs down and usually drips on the sub frame which in it self is a bad design.
Turn the AC on and condensate should drip from the drain after running it for a while
Busted_PT and boonie2 like this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 07 Jun 2014, 01:21 pm
You have your air conditioning on, right?
There's a drain that is clogged - sorry, I can't direct you to it, but it's there on passenger side.
soonercruiser likes this.
Old 07 Jun 2014, 01:30 pm
It took a little bit of digging (and waiting for my engine to cool off enough) but I found the drainage hose and yes, it was quite clogged. A LOT of water came pouring out of it when I was able to clear the blockage, which only took squeezing the hose a little bit.
Thanks for all of your help!!!
Old 07 Jun 2014, 08:57 pm
Good job! Tell your hubby he has to cook now.
JuneBug likes this.
Old 07 Jun 2014, 11:13 pm
soonercruiser's Avatar
Thumbs up Re: Water draining into passenger floorboard
Great job, Don!
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
2003 GT as the new Day Driver - being converted to a Panel PT
Old 14 May 2017, 01:18 pm
Old post but can you elaborate more on where found the AC Drain? I'm having this exact same issue.
Old 14 May 2017, 02:04 pm
sanatanadharma's Avatar
Motor compartment firewall on passenger side
Down low
Tags
air conditioner, water leak
Water leaking onto floorboard drivers side JolieCruiser General PT Cruiser Discussions 22 25 Jul 2015 07:48 pm
Water Leak From Under Passenger Side Dash jwlast General PT Cruiser Discussions 8 20 Jun 2014 06:42 pm
Mystery Floorboard Fluid GoingGreen Tech & Performance Forum 6 19 May 2012 08:29 pm
Exterior Water Leak to F.R. floorboard Lakota General PT Cruiser Discussions 9 02 Dec 2011 09:26 pm
Issues - Rear passenger blinker out, passenger window not working eobryant Tech & Performance Forum 0 23 Apr 2010 12:51 am
