Go Back   PT Cruiser Forum > Regional Forums > Gulf PT Forum
Ecm not grounding some relays
Old 28 May 2017, 04:38 pm
Angry Ecm not grounding some relays
It started out with my ac high pressure valve releasing pressure. Having gone through this issue before, I immediately checked my cooling fan. No voltage there so I checked my relays for both high and low speed and the relays are fine. Then I bypassed the high speed relay and my fan works.
Later, I get a CIL and the codes are P0480, P0481, P0645. After checking fuses and relays for both fan speeds and the ac relay, I found out that the ecm isn't sending ground to those relays.
I have a 2005 pt cruiser touring edition, no turbo, but the temp sensor is mounted like it's the turbo motor.
Could the ECT be bad even though the temperature gauge is still working and I don't experience engine problems?
Old 28 May 2017, 09:24 pm
Default Re: Ecm not grounding some relays
PTgurls, Please Introduce your self and tell us about your PT...
What parts your from, year make and model, mileage will do..
and what ever you do fix your problem, please don't leave us hanging
buy just fading away, let us know "The FIX"
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Tags
ac clutch, cooling fan, ecm, grounding, relays
Stereo Grounding? rckstein Sound and Security Forum 2 18 Apr 2014 10:49 pm
hyper grounding yteka99 Sound and Security Forum 18 22 Jun 2009 03:35 pm
Anyone ever install a "grounding" kit before? Wicked_PT General PT Cruiser Discussions 6 05 Dec 2005 08:25 pm
Hyper Grounding Mean Green Turbo Performance 25 19 Nov 2004 02:57 pm
Grounding sites for gauges PTGT Redman Tech & Performance Forum 7 25 Jan 2004 04:55 pm
